#1 2020-06-15 06:55
dannician
Running ReNamer automatically with a set of rules (command line use)
Is there a feature to open the program and run a set of rules automatically?
#2 2020-06-15 06:59
Re: Running ReNamer automatically with a set of rules (command line use)
Please see if you can make use out of that information > https://www.den4b.com/wiki/ReNamer:Command_Line
#3 2020-06-15 07:02
dannician
Perfect thank you!
#4 2020-06-15 18:58
dannician
I am experiencing an interesting problem with the sort order.
Using the command line parameter
/preset <preset> <files>
The sort order of the results are out of order. It skips around in the number sequence. See below:
out or order
When I manually enter the folders first and then choose the rules second the sort order is correct.
order correct
The problem is that the command line parameters use the rules first and this always makes the sort order wrong.  Is there a way to have the command line parameters select the folders first and the rules second?
#5 2020-06-21 13:18
Thank you for reporting this issue.
It has been rectified in version 7.2.0.3 Beta. Please try the latest development version.
