#1 2020-06-27 18:39
oem
Force Break and Infinite Pascal Loop
Just wondering if there is a way to force break pascal in renamer?
#2 2020-06-27 19:29
Re: Force Break and Infinite Pascal Loop
Hi, see there >> http://www.den4b.com/wiki/ReNamer:Pasca … uick_guide
Break;     //Ends the current subroutine / loop.
Continue; //Skip the current subroutine / loop for the current file.
Exit ;      //Me think this can be used like break too for our simple scripts, or can also terminate the whole script.
if <Condition> then xxxxx;
But I don't know for sure when to use what, would be nice if den4b can bring in some light ;-)
#3 2020-06-27 20:26
I would describe it as:
Break - Ends the current loop.
Continue - Skips the current iteration of a loop.
Exit - Terminates the current routine (function or procedure).
#4 2020-07-10 10:45
oem
Hey.. im talking about once its already running.  I have accidentally created an infinite loop and with a pop up message and I cant get it to stop. Force Quitting will mean ill lose my progress.
#5 2021-02-08 09:25
oem
Theres no way to do this?
#6 2021-02-09 10:28
oem wrote:
I'm talking about once its already running. I have accidentally created an infinite loop and with a pop up message and I cant get it to stop. Force Quitting will mean ill lose my progress.
Unfortunately, at this moment, there is no way around it. I'll put a feature request for this, but it will be a low priority.
In the meantime, the only thing I can suggest is saving the preset more often, i.e. between the edits.
