#1 2021-03-10 05:26
Eagles
Mass copy files to same name folder
I'm a beginner of pc user and have the task to do from office.
Can renamer copy all of the image files to the same name folders separately and automatically and ? since I have more than thousands of files need to copy to the same task.
Thank you very much!
#2 2021-03-10 10:50
Re: Mass copy files to same name folder
ReNamer does not copy files, if that is what you are after. It renames (moves) files.
With that said, it is quite easy to put files into individual folders named after their base name, without the extension.
You can achieve that using the meta tags and the Insert rule, with the following rule configuration:
> Insert ":File_BaseName:\" as Prefix
Here is a quick demo:
#3 2021-03-10 15:05
Eagles
Thank you very much , Admin.
