#1 2023-04-20 00:17
UCG Musician
Copy rules from another preset
I have a preset that I'd like to modify by copying a set of rules from another preset.  Does ReNamer support this?  If so, how is it done?
#2 2023-04-20 02:08
Re: Copy rules from another preset
You can append another preset to the existing rules via the Presets Manager.
You can also quickly append a preset by holding down the SHIFT key when loading it via the Presets » Load menu.
#3 2023-04-20 02:21
UCG Musician
It worked!  Thank you!
