#1 2023-06-06 19:20
Pawel
Save to a folder one level up
I am asking for help in writing a rule that will allow me to save multiple files at the same time one level higher.
Example:
D:\Photo\1\temp\a.jpg >> D:\Photo\1\a.jpg
D:\Photo\2\temp\b.jpg >> D:\Photo\2\b.jpg
D:\Photo\3\temp\c.jpg >> D:\Photo\3\c.jpg
#2 2023-06-06 20:57
Re: Save to a folder one level up
That's easy. Simply insert "..\" as a prefix to your filenames.
You can inspect the full target path via the "New Path" column.
See also Renaming to another folder.
