#1 2023-08-03 09:26
klapvogn
Reindex episode numbers
I have this :
MASH.S10E01.NORDiC.720p.WEB.H264.AAC2.0-TWASERiES
MASH.S10E02.NORDiC.720p.WEB.H264.AAC2.0-TWASERiES
They are part 1 and 2, so my plex can handle it correctly, so is there a way to rename it correctly?
I mean when I put it back in it's folder it would go like this:
MASH.S10E03.NORDiC.720p.WEB.H264.AAC2.0-TWASERiES
MASH.S10E04.NORDiC.720p.WEB.H264.AAC2.0-TWASERiES
MASH.S10E05.NORDiC.720p.WEB.H264.AAC2.0-TWASERiES
#2 2023-08-03 11:30
Re: Reindex episode numbers
klapvogn wrote:
I have this :
I don't get it.
What would be your correct name?
What and how do you want to rename?
xxx
xxy
#3 2023-08-03 14:10
klapvogn
What I have after I have merged
- as they are part 1 and 2
So now I have :
But now when I put it in the folder with the rest I have:
Can renamer fix the episode order so it goes from E01 to E24
#4 2023-08-03 15:10
These rules will re-index all episode numbers according to the order in which they appear in table.
1) Insert: Insert "." as Prefix
2) Serialize: Incremental from 1 repeat 1 step 1 and pad to length 2 as Prefix
3) Regular Expressions: Replace expression "\A(\d+)\.(.*)\b(S\d+E)\d+\b" with "$2$3$1"
Just make sure you sort your files before applying these rules.
Example input:
S10E01
S10E03
S10E04
S10E05
S10E10
S10E999
Output:
S10E01
S10E02
S10E03
S10E04
S10E05
S10E06
#5 2023-08-03 17:06
klapvogn
Thanks, i'll give it a shot smile
