#1 2023-08-12 02:53
shuntensatsu
feature request/suggestion: preset modules/groups
ReNamer is one of my must have tools, there is one thing that would make it even better.
If it was possible to load presets as "modules".
say I got preset A that cleans files
then I got preset B that orders files
then I got preset C that finalizes files
it would be awesome being able to load a preset group:
it would go through the preset group "modules" (preset A, preset B, preset C) in one go.
currently I have to load preset A, run that, then load preset B, run that, then load preset C and run that.
you may ask, but why don't you just create a preset with all the rules of preset A, B and C in it?
sometimes you don't need all the rules in each preset or want to add preset D or E, so it's tedious having to edit/change/modify or remove rules based on different needs. it would be nice to load presets as required, but run them in one group at once.
#2 2023-08-16 07:09
Re: feature request/suggestion: preset modules/groups
Indeed, this would be a great improvement. It has been suggested a few times in the past and it is already on the todo list.
I can't give you any concrete timelines, but you can subscribe to this thread to get notified when there is an update.
#3 2023-08-16 08:14
shuntensatsu
I am happy with that reply, take your time.
