#1 2007-08-15 21:04
Sebastian Mares
Renamer 4.65 - Possible RegExp Bug
Is it possible that Renamer has problems finding closing parenthesis? \( works fine, but \) not.
#2 2007-08-15 21:12
Sebastian Mares
Re: Renamer 4.65 - Possible RegExp Bug
Hey, I found the problem! Renamer thinks that everything after the first dot is the extension, which I believe is incorrect - at least I would expect it to see the last dot and everything after it as extension.
The problem was that my files were named like "blah blah (blah@blah.blah) blah blah" and I wanted to extract everything inside the brackets while deleting the rest. Since I had the "skip extension" box checked, the closing parenthesis was treated as part of the extension.
#3 2007-08-16 02:16
The extension is the part after the last dot, i just checked it with renamer.
In your file "blah blah (blah@blah.blah) blah blah" there is only 1 dot...
Do you still have problems with it?
