#1 2007-09-19 02:37
Quaraxkad
Renaming over a network
I have shared folders on my file server (e.g. \\file-server\folder\). If I rename files in a shared folder, Renamer will make new folders and put the files in them.
Renaming files in:
moves the files to the new location:
\\file-server\folder\file-server\folder\
The "validate new names" option also thinks the filenames are invalid.
#2 2007-09-20 15:23
Re: Renaming over a network
I never stated that windows network files were supported by ReNamer wink
Anyway, I made few adjustments, and it should work fine for network files as well.
Try it, and tell me how it goes, ok?  ReNamerBeta.zip
#3 2007-09-20 15:33
Quaraxkad
Should this have been in the Suggestion forum instead of Bugs?
Works perfectly, thanks!
#4 2007-09-20 17:30
mltsy
I just downloaded ReNamer today and had the same issue.  Thank you!!
Great program smile
#5 2007-09-20 23:09
Actually, it's good that you posted it in Bugs forum. That made me FIX the problem faster! tongue
mltsy wrote:
I just downloaded ReNamer today and had the same issue.  Thank you!! Great program
Glad to hear that! big_smile
#6 2008-04-08 09:26
demokrates
I will rename all files in my network-folder
\\Salf\austria\BüroIsmaning\*.*
If I klick "Add Folders"
I can not see my windows-network !!?
are there a possibility
to pick up my windows-path  \\Salf\austria\BüroIsmaning\  manually per copy / paste to "Add Folders" ?
#7 2008-04-08 10:38
Hi demokrates, welcome to the forum.
Work around:
First solution: you could just map your unc folder
Or you could drag&drop your "BüroIsmaning" -Folder into ReNamers "Drag your files here"-panel (check ReNamers Filter Settings too)
best
#8 2008-04-15 13:46
demokrates, this is not a bug.
"Add Folders" dialog is a custom built dialog, to provide legacy way of adding folders. It simply wasn't meant for showing network paths. One simple reason: it will dramatically slow down the performance of this dialog because it will have to search for network folders.
You can use other methods like Drag&Drop, Copy&Paste, CommandLine to add your network folders!
