#1 2006-04-18 16:24
thems5
Replacing names according to Excel list
This is the way I suggest:
a. exporting current file names in a given folder to an Excel list (column A).
b. filling the new requested names in the Excel file (column B). Each new name in column B should replace the old name in column A in the same raw
c. pressing a "REPLACE" button to replace all the original names in the folder with the new names.
#2 2006-04-20 10:52
Re: Replacing names according to Excel list
Thems5, did you see the "Export file table contents" option?
You can export into a CSV file, which will be opened by Excel... Will that work for you?
It's exporting the table as it appears in ReNamer: Column A = Directory, Column B = Original Name, Column C = New Name.
So I can add "Import file table contents" option, which will fill up the table in exactly the same manner... will that do the job?
#3 2006-04-20 20:18
thems5
Yes, I did try the export file name option.
But I only had coloumns A and B.
I suppose you mean that you plan to add column C (new name) to the Excel file, in which the user will fill the new requested names.
I am not sure I understand what will "import file name contant" do.
If it will replace the file names according to the Excel list (each name in column B with the new name in the same raw in column C), it would be great.
Is that what you meant?
#4 2006-04-20 22:21
You had only columns A and B because you only had 2 filled columns in the files table in ReNamer, i.e. new names were empty. If you preview first, even without any rules, to fill up the new names - then export it to the CSV file and you'll get 3 columns wink
As I wrote in the previous post: Column A = Directory, Column B = Original Name, Column C = New Name. Export the files table, then fill up the 3-rd column with your new names, and then Import it - you'll see the results!
By the way, I've just added "Import file table contents" option to ReNamer! Try it from here:
http://www.redbrick.dcu.ie/~den4b/Projects/ReNamer/ReNamerBeta.zip
#5 2006-04-21 11:24
thems5
It worked perfectly the first time, but in the second time I had error message: I/O error 103.
When I gave the import order, I had the error message and the names diappeared from the list (in Renamer).
By the way - can you please explain how can I rename files names 1, 2, etc, to 1,jpg, 2.jpg etc?
Many thanks
#6 2006-04-24 11:20
I\O error 103 means that ReNamer can't open the file. In your case it probably means that the file that your are trying to import is LOCKED by another application - by Excel if you are using CSV files. The workaround is to close Excel, and then import the CSV file.
By the way, I found a way to read locked files, you can download the dev version, or wait till I release a new version of ReNamer (should be later today).
thems5 wrote:
can you please explain how can I rename files names 1, 2, etc, to 1.jpg, 2.jpg etc?
Yes, just use "Extension" rule, and enter "jpg" as your new extension in the rule's configuration smile
#7 2006-04-24 14:30
thems5
Thank yoy Denis.
Your support is very helpful!
