#1 2007-09-30 18:30
ozzii
Delete some and keep some
here is what I would like to do:
I have this aaaa.s01e01.bb
and I would like to have as result aaaa.101.bb
I want to delete the s0 and the e
Now I have to create a replace rule but I have to put in a lot of things and to keep it update
Is there a way to say (for regex or pascal for example) one character and to reuse the same in replacement.
Let me explain: into find: s0?e?? into replace: ???
So I will have find s01e01 s01e02 s01e03 and for result 101 102 103 because I will always keep the 3,5 and 6 characters.
Am I clear ?????
_________________
#2 2007-09-30 21:55
Re: Delete some and keep some
Yes, you can use wildcards for this task. Just tick the option at the bottom of the config screen for Replace rule.
Find: s0?e     Replace: $1     Use Wildcards: Yes
#3 2007-10-01 09:14
ozzii
Working !!!!!!!!!!!!!!!!
Thanks a lot
_________________
