#1 2008-01-09 01:16
ronnie_t
Rename files by m3u-file
Hi, I love this program. I wrote my first script. I am sharing it, so others can use it. It's probably not very efficient right now, but i'll learn.
What it does:
- It renames all music files in a directory through the .m3u file.
How to make it work:
1. Create a directory and put your files in them (mp3, wav, etc). For the moment it's only important the files start with a tracknumber (e.g. 3 BLA.mp3, otherwise sorting is difficult).
2. Create a m3u file with the EXACT name of the directory it's in (e.g. if you music-files are in c:\Madonna\, then the m3u file must be named Madonna.m3u and placed in c:\Madonna\.
3. Put the wanted filenames in the m3u file. The name may be anything with legal characters.
4. Import files and run script.
// Read m3u file and rename files accordingly //
  I: Integer;
  Position: Integer;
  FileNameLength: Integer;
  PathNameLength: Integer;
  PathName: string;
  FolderName: string;
  UserInput: WideString;
  NewFileName: string;
  TrackNumber: string;
  FileExt: string;
  FileNameLength := Length(FileName);
  PathNameLength := Length(FilePath);
  PathName := FilePath;
  NewFileName:= FileName;
  for I := FileNameLength downto 1 do
      if (FileName[i] = '.') then
          Position := I;
          break;
  Delete(NewFileName, Position, FileNameLength);
  for I := PathNameLength downto 1 do
      if (FilePath[i] = '\') then
          Position := I;
          break;
  Delete(PathName, Position ,PathNameLength);
  for I := Length(PathName) downto 1 do
          Position := I;
          break;
  FolderName:= PathName;
  Delete(FolderName, 1, Position);
  PathName := PathName + '\';
  Position := 1;
  if (WideFileExists(PathName+FolderName+'.m3u')) then
      for I := 1 to Length(NewFileName) do
          if (IsWideCharDigit(FileName[i])) then
              Position := I;
            end
          Else
            break;
      if Not (Position = 1) then
          TrackNumber := FileName;
          Delete(TrackNumber, Position+1, FileNameLength);
          UserInput := FileReadLine(PathName+FolderName+'.m3u', StrToInt(TrackNumber));
          Position := 1;
          for I := Length(UserInput) downto 1 do
              if (UserInput[i] = '.') then
                  Position := I;
                  break;
              FileExt := UserInput;
              Delete(FileExt, 1, Position-1);
              if Not (WideExtractFileExt(FilePath) = FileExt) then
                ShowMessage('FileExtention ('+WideExtractFileExt(FilePath)+') does not match m3u playlist ('+FileExt+')')
              Else
                FileName := UserInput;
            end
          Else
            ShowMessage('Filename "'+UserInput+'" (Line '+IntToStr(StrToInt(TrackNumber))+') has no extention!');
        end
      Else
        ShowMessage(Filename+'does not start with a number!');
    end
  Else
    ShowMessage(PathName+FolderName+'.m3u does not exist!');
update January 10, 2008:
- previous script did not work without my other rules (i didn't include) roll
- ignore leading zero's
- added some checks for validation
#2 2008-01-09 17:00
Re: Rename files by m3u-file
Thank you for sharing, ronnie_t
#3 2008-01-16 13:12
