#1 2008-01-21 06:19
Fiorello
Remove text until "-" (dash)
Hello everybody!
I would like to remove text from files until " - " like in the string "Sting - All This Time.mp3" - so there remains just "All This Time.mp3".
Could anybody tell me how to realize with Renamer?
Many thanks in advance!
Fiorello
#2 2008-01-21 12:03
Re: Remove text until "-" (dash)
Fiorello
Hi Fiorello, welcome smile
If you have only files like your example (and with one dash only) you could use this RegEx-Rule
This means: Find all .+ till space-dash-space(and the rest)
Replace with what is in "the rest" by using $1
If you have file names with an other structure then your given example this RegEx may fail roll
HTH? tongue
See you...
#3 2008-01-21 14:53
Hi Fiorello smile
You can simply use the Delete rule, from position 1, until the delimiter " - ". As easy as that.
P.S. Stefan, don't be scaring away new users with RegEx just yet tongue
#4 2008-01-21 18:09
Hi Fiorello smile
smile very fine!
This may be meant as fun, but is very true as well! Of course you're right. ReNamer have many power features without need power user to work well.
(on the other hand i though you where away for longer and so i think my answer was better then nothing big_smile)
#5 2008-01-21 18:50
I only meant it as a joke, even tho there is a bit of truth in it wink
Anyway, quick and dirty answer is sure better than no answer!
#6 2008-01-23 11:59
Fiorello
Wow, many thanks for your great help!!! Good Job! Keep on goin'! smile
Fiorello
