#1 2008-05-25 18:31
airjrdn
Pascal script to XOR encrypt filenames?
I have a couple of questions...
I've been using ReNamer a long time and love it, but I'm not sure how to accomplish this one.
Before backing files up to an online backup service, I wish to encrypt the filenames.  Since I don't have the space to make copies of the files, here's my thought.
Encrypt the filenames
Run the backup
Decrypt the filenames
The encryption needs to be able to easily flip the filenames back and forth between encrypted and unencrypted, hence my thought on using XOR.  I'm no Pascal programmer though, so I'm not sure how to do that using ReNamers powerful PascalScript rule.
My second question is, whether or not it's possible to call ReNamer from a command line, passing it a Preset to use, and a directory (and parm for subdirectories).  So, to automate my scenario above, I could just call it, run the backup, then call it again to rename the files back to normal again.
For safety reasons, I could do hardlinks I guess, but that could be version 2.
#2 2008-05-25 18:35
airjrdn
Re: Pascal script to XOR encrypt filenames?
I just found out that ReNamer does support command lines via this thread.
"C:\Program Files\ReNamer\ReNamer.exe" /preset "MyRulesPreset" "D:\Pictures\*.jpg"
#3 2008-05-25 20:17
airjrdn
Here's a lame attempt at accomplishing my goal, but using Translit
encode
a=$01$
b=$02$
c=$03$
d=$04$
e=$05$
f=$06$
g=$07$
h=$08$
i=$09$
j=$10$
k=$11$
l=$12$
m=$13$
n=$14$
o=$15$
p=$16$
q=$17$
r=$18$
s=$19$
t=$20$
u=$21$
v=$22$
w=$23$
x=$24$
y=$25$
z=$26$
0=9
1=8
2=7
3=6
4=5
5=4
6=3
7=2
8=1
9=0
decode
$01$=a
$02$=b
$03$=c
$04$=d
$05$=e
$06$=f
$07$=g
$08$=h
$09$=i
$10$=j
$11$=k
$12$=l
$13$=m
$14$=n
$15$=o
$16$=p
$17$=q
$18$=r
$19$=s
$20$=t
$21$=u
$22$=v
$23$=w
$24$=x
$25$=y
$26$=z
0=9
1=8
2=7
3=6
4=5
5=4
6=3
7=2
8=1
9=0
However, decoded letters come back as all caps.
#4 2008-05-26 16:07
krtek
I think you can use xor in PascalScript.
Below I've written scripts for encoding/decoding using CASE statement (and only for first twelve CAPITAL letters, the rest is up to you).
I think you will find out what is what and if you would prefer to use xor, you'll do that smile
//encoding
  character, TempName, BaseName, Extention: WideString;
  i: Integer;
  BaseName:=WideExtractBaseName(FileName);
  Extention:=WideExtractFileExt(FileName);
  TempName:='';
  character:='';
//  BaseName:=BaseName+Extention     //uncomment that line if you would like to apply encoding also to extention
  for i:=1 to Length(BaseName) do
    character:=WideCopy(BaseName, i, 1);
    case character of
      'A': character := '$01$';        //here you can enclose your encoding routine
      'B': character := '$02$';
      'C': character := '$03$';
      'D': character := '$04$';
      'E': character := '$05$';
      'F': character := '$06$';
      'G': character := '$07$';
      'H': character := '$08$';
      'I': character := '$09$';
      'J': character := '$10$';
      'K': character := '$11$';
      'L': character := '$12$';
    else ;
    TempName:=TempName+character;
  FileName:=TempName+Extention;
decoding
//decoding
  character, temp, TempName, BaseName, Extention: WideString;
  i: Integer;
  capturing:  boolean;
  capturing:=false;
  TempName:='';
//  BaseName:=BaseName+Extention     //uncomment that line if you would like to apply decoding also to extention
    temp:=WideCopy(BaseName, i, 1);
    if capturing = false then character:='';         //
    if temp = '$' then                               //treat anything between two $'s as one character
      if capturing=false then
          capturing:=true
      else
          capturing:=false;
    character:=character+temp;
    if(capturing = false) then
        case character of
          '$01$': character := 'A';        //here you can enclose your decoding routine
          '$02$': character := 'B';
          '$03$': character := 'C';
          '$04$': character := 'D';
          '$05$': character := 'E';
          '$06$': character := 'F';
          '$07$': character := 'G';
          '$08$': character := 'H';
          '$09$': character := 'I';
          '$10$': character := 'J';
          '$11$': character := 'K';
          '$12$': character := 'L';
        else ;
Let us know how it works.
Cheers,
Konrad
#5 2008-05-26 16:08
krtek
And I suggest using new feature: "Save filter with presets" when you're preparing presets for command line usage...
#6 2008-05-26 18:01
airjrdn
Thanks, I'll give this a shot.
#7 2008-05-26 21:16
Here is a XOR encryption of the filename, against an integer key:
  KEY = 12345;
  C: Char;
  I: Integer;
  for I:=1 to WideLength(FileName) do
    C := WideToAnsi(FileName[i])[1];
    FileName[i] := Chr(Ord(C) xor KEY);
WARNING: This encryption will do you no good, because most of the characters will come out as "unprintable", "forbidden", or even "control" characters!! Also, this simple implementation discards the Unicode characters, so it will work properly only for English/ANSI characters!
I would suggest using a map, like you have tried. Or you can use XOR encryption, but output characters in a HEX format.
Tell me if you need more help with it..
#8 2008-05-26 23:07
airjrdn
I really appreciate the help.  I'll give it a try tonight after the kids are in bed.
The main issue I'd have w/my first solution is that all of them come back as all caps.
#9 2008-05-26 23:24
krtek
I guess the problem with translit rule is that when you substitute a letter with something that's not a letter it stops producing pairs of lowercase-uppercase letters (as it can no longer do it by simply add/substract 32 to an ascii code).
I don't know what's the purpose of the encoding filenames, so that might not be helpful, but if you substituted letters with letters (and not $dd$) then the translit rule should work as well.
#10 2008-05-27 14:58
I thought about it, and decided that it might become useful for a large group of users.
So I decided to make a proper script for encrypting filenames. It uses a XOR-BASE64 method: XOR encryption against a given string KEY, with modified BASE64 encoding (not a standard MIME BASE64) to make valid filenames. For the script to work you will need to use the latest development version: ReNamerBeta.zip (27 May 2008)
Anyway, all you have to worry about are the 2 constants at the top of the script: KEY and DECODE. KEY should any text - which is your secret key. DECODE should be a "True" if you are decoding filenames, and "False" if you are encoding filenames. Script is included in the latest development version, but for the reference it is also included in this post (below).
NOTE: Make sure you test it first, before encrypting your filenames for good!
{ XOR-BASE64 Encrypt Filename against a String Key }
  KEY = 'My Secret Key'; // Set your key!
  DECODE = False; // "True" or "False"
function XorEnDeCrypt(const S: String): String;
  I, IK, Code: Integer;
  IK := 1;
  Result := '';
  for I := 1 to Length(S) do
    if IK > Length(KEY) then IK := 1;
    Code := (Ord(S[i]) xor Ord(KEY[IK]));
    Result := Result + Chr(Code);
    IK := IK + 1;
procedure ReplaceChar(var S: String; Find, Replace: Char);
  I: Integer;
  for I:=1 to Length(S) do
    if S[i] = Find then
      S[i] := Replace;
function Encrypt(const S: WideString): String;
  Result := UTF8Encode(S);
  Result := XorEnDeCrypt(Result);
  Result := Base64Encode(Result);
  ReplaceChar(Result, '/', '=');
function Decrypt(const S: String): WideString;
  Temp: String;
  Temp := S;
  ReplaceChar(Temp, '=', '/');
  Temp := Base64Decode(Temp);
  Temp := XorEnDeCrypt(Temp);
  Result := UTF8Decode(Temp);
  if DECODE then
    FileName := Decrypt(FileName)
  else
    FileName := Encrypt(FileName);
