#1 2009-02-08 10:53
narayan
Add hyphen to Cleanup dialog
The Cleanup dialog lists commonly used characters such as comma, period, underscore.
It does not mention a very commonly used character: hyphen (-).
Please include hyphen (-) in the list also.
#2 2009-02-08 10:59
Re: Add hyphen to Cleanup dialog
I supose that you are speaking about ReNamer and I agree with the suggestion. wink
#3 2009-02-08 11:11
narayan
I saw this comment somewhere else also! Is this forum common for many products? Then yes, the comment is for ReNamer!
#4 2009-02-08 15:44
eR@SeR
I agree with you also. There is a examlpes, mostly for images, that have pattern like "word-word-word-digit" and I have need for space replacement. I did that via Replace rule but CleanUp will be more practic.
Yes, for all of Denis' products (ReNamer, Shutter, CPUMon, Hasher, Hooker). You have to emphasize which one you talking about...for example you could write "ReNamer: Add hyphen to Cleanup dialog".
#5 2009-02-10 00:20
I've added "-" (hyphen) to the CleanUp rule. Available in latest dev version.
P.S. eR@SeR, I think this question has been asked before. Try to find that answer tongue
#6 2009-02-11 14:43
One appointment, I've tried this option on the beta, and works well, but... If you only mark that option the rule description appears empty, and marking also with skip version remains empty.
Combined with other symbols the description looks to work well.
#7 2009-02-11 22:52
