#1 2009-03-15 20:37
krtek
WideRenameFile does not create folder if it doesn't exist
It might be intended but I've noticed that WideRenameFile function does not create folder if it doesn't exist. It failes to rename/move file then. But if folder exists, it will move the file.
This behaviour is a bit different from what normal renaming operation does.
#2 2009-03-15 21:23
Re: WideRenameFile does not create folder if it doesn't exist
That is correct.
Windows does not automatically create folders when you are moving/renaming files to not existing folders. User have to create those folders prior to moving the file. In case of main "Rename" action, I actually force all directories to exist prior to renaming.
#3 2009-03-15 22:18
krtek
Thanks for explanation.
