i'll be glad if a day this great tool will be able to generate multiple files, following a syntax.
For example actually I need to create more than 1100 .css files, with a custom code for everything.
I mean something to create multiple filenames following a syntax, and could be great if it can change the values of some parameters into the file (for example a value from A001-D change in the next file to A002-D and so on)
Thank you all!
This kind of tool that you are describing can be coded up, but it will be a completely separate tool. There is no real connection between this application and ReNamer (a tool for renaming files).
You are right!
I've found a tricky solution, called Powershell, I've created and generated the text of 10,000 files in some minutes.
It rocks but is necessary to know coding.
Thanks however
