Most of the time Count marked and selected works fine.
But I saw it fail twice. One of them I managed to reproduce:
4 files it the Files pane:
- first and last files marked
- first and second files selected
Result of counting:
Total: 4 (should be 3)
Marked: 2
Selected: 2
You got me puzzled here...
There are 4 files in the table, but you say it should say 3 ??
"Total" stands for total number of files in the table.
Am I missing something?
Now, I'm puzzled.
As I tested the option, everything was pointing that Total stays for joint of Marked and Selected (the common part).
Now, I see that total means total number of files in files pane...
And everything is in a full harmony.
Sorry, again.
