After the first time of renaming of program files began to work clumsily: in the program in preliminary sort renaming files go on-order, after renaming of files the counter glorks and produces not clear digits from true, that is differ from those which I set + does them in dispersion how to repair such bug?
Could you explain it better?, an example (maybe an image) would help...
It is difficult to explain screenshots. To produce the program there were random simply digits in the end of names of files instead of as should be in the counter, but such problem only if in a folder is under folders. But I rename the folder where the files are not changed, delete and add new files only as a result of the program was renamed in the same folder my_music_7000 to another (that goes for her) my_music_7121 as exhibited in the counter to a report from 7200
I'm sorry, but while SafetyCar apologizes for his bad English in his sig, you're the one who's completely unintelligible, DeepSoul. What are you trying to say? Screenshots, examples... Anything would be better than trying to read your words and make sense out of them... Are you using an online translator by any chance?
As far as I can see from here you are using Russian version of ReNamer so you can describe in Russian. Denis (author) or someone else can understand you better what are you trying to say/describe and give you an explanation. Cheers
Yes, that's an excellent suggestion. If your native language is indeed Russian, feel free to post in it so that you can express yourself far more easily, than struggling with a language that you're obviously not comfortable with.
DeepSoul, do you steel need help on this topic?
Тебе еще нужна помощь по данной проблеме? Можешь писать по русски!
