I made these rules:
3) RegEx: Replace expression "(.*)( vs.*\-)(.*)" with "$1-$3" (skip extension)
4) RegEx: Replace expression "(.*)( feat.*\-)(.*)" with "$1-$3" (skip extension)
5) RegEx: Replace expression "(.*)( ft\..*\-)(.*)" with "$1-$3" (skip extension)
I have:
foo vs bar-result.mp3
foo feat bar-result.mp3
foo ft. bar-result.mp3
And the result required is:
foo-result.mp3
Is it OK? Is there a better way (maybe with rearrange)?
To resum I would like to truncate from "vs|feat|ft." until the last "-"
_________________
Do, or do not. There is no 'try.'" -- Jedi Master Yoda
They seem ok, although it would be safer to check for a space after "vs|feat|ft." in the pattern, so you can elminate the case when these are parts of some words, for example: "foo vsop bar-result.mp3" -> "foo-result.mp3".
Alternatively, you can use Delete rule, form delimiter to delimiter. It should work faster than RegEx but it will work only with the first found delimiter, so you can replace last delimiter with some unusual character and then use it in Delete rule.
Hi ozzii, just some thought:
- you don't need to ()-group what you don't need in replacement,
so "(.*) vs.*\-(.*)" with "$1-$2" should work too.
- you don't have to escape the '-' dash into ()-groups,
only between '[' and ']' and there only if he is not on first or last position
so "(.*) vs.*-(.*)" with "$1-$2" should work too.
- you can use (this|or|that) "OR"-construct like
so "(.*)\s(vs|feat|ft.)\s.*-(.*)" with "$1-$3" should work too.
Explanation:
(.*) ==> match null-or-more of any sign till
\s ==> an space followed by
(vs|feat|ft.) ==> vs OR feat OR ft., followed by
.*- ==> null-or-more of any sign till an dash, followed by
(.*) ==> null-or-more of any sign till the end
HTH?
Thanks for the answer (both of you of course...)
I will test the 2 possibility.
Thanks again
_________________
