Today I saw this strange thing
Exp: (.*)
Rep: $1#
Input: example
Output: example##
Why 2 times? And with (.*)$ keeps doing the same but not with ^(.*)
Is there any logical explanation for this?
- - - UPDATE - - -
I changed the order an I get this
Exp: (.*)
Rep: #$1
Input: example
Output: #example#
It's happening both on analyze text window and on file list
This seams like an b,ug in the regex implementation related to greedy/non-greedy.
To help Denis if he want to find this, i have tested this behaviour
with buid "5.50 (3 May 2009)" and got the same result as SafetyCar .
# is an placeholder for all kind of strings ( like 'P' or 'New-' , no matter)
And the same was found by using '$0'
The workaround is to use an leading ^ before the expression, as SafetyCar already mentioned.
Now as i am on, i found more:
$1 New
$1 New
$1 New $2
Ahh, this works:
(x.*)
$1#
or
(.*x)
$1#
where 'x' represents the first/last char of an string. Now it seams that there is an problem with the dot?
That's a serious problem. How come we didn't notice it before?
I just wanted to report it to the developer of this RegEx engine, but couldn't access his web site. I can't fix it on my end, it can take weeks and weeks of going through RegEx engine code to find the problem.
We'll have to live with this problem for now, until either the problem is fixed by the developer or I change the RegEx engine to another implementation.
I wondered something similar when I saw it
I tried:
Exp: (a?) (but not (a+))
Rep: xxx$1
Input: a
Output: xxxaxxx
So it's not the dot. The example is pretty representative, but I don't know how to explain my conclusions
But I bet you can understand me without saying it
I did another test
Exp: (.*)
Rep: $1_$1_$1_$1_$1_$1
Input: a
Output: a_a_a_a_a_a_____
It's like it was dividing the string into 2 strings, but the second one is empty, and once processed are joint
I don't know if you noticed it, but http://regexpstudio.com/ is online again, maybe you can contact them now?.
