I have several scripts to re-arrange music files based on the ID tags (Author & Album mainly). I found the metatags to handle mp3 (ID3), wma, flac, but cannot find the equivalents for m4a files. Any suggestions?
As of this moment, there is no support for tags in m4a/mp4 formats.
The only suggestion that I can give you is to try using some command line tool which can extract tags from m4a files. Then you can incorporate the output of that tool into ReNamer, via PascalScript rule.
There several examples on wiki and forum, e.g.: ReNamer:Scripts:Exiv2.
