Can someone provide me a pascal script (I thing that it can do it) for adding at the end of folder the number of txt files in it.
For example I have:
C:\TEST\test1.txt
C:\TEST\test2.txt
C:\TEST\test3.txt
And after I would like to have:
C:\TEST(3)\test1.txt
C:\TEST(3)\test2.txt
C:\TEST(3)\test3.txt
Thanks in advance.
_________________
Do, or do not. There is no 'try.'" -- Jedi Master Yoda
Try with this
Files: TStringsArray;
BasePath: WideString;
BasePath := WideExcludeTrailingPathDelimiter(WideExtractFilePath(FilePath));
SetLength(Files, 0);
WideScanDirForFiles(BasePath, Files, False, False, False, '*.txt');
FileName := BasePath + ' (' + IntToStr(length(Files)) + ')\' + FileName;
end.If this software has helped you, consider getting your pro version. :)
This is almost it.
One problem, I have a new folder created at each run with the new number.
OLD:
C:\TEST\test1.txt
C:\TEST\test2.txt
C:\TEST2\test1.txt
C:\TEST2\test2.txtRESULT
C:\TEST\
C:\TEST(2)\test1.txt
C:\TEST(2)\test2.txt
C:\TEST2\
C:\TEST2(2)\test1.txt
C:\TEST2(2)\test2.txtAny way to rename the existent folder or maybe to delete the old folder after the rename (only when the rename occur) ?
Am I clear ?!!? I'm not sure !!
_________________
What I would do is add the folder instead of the files. (Add folders as files: http://www.den4b.com/wiki/ReNamer:Filte … lters_menu)
And then use this to get the new name for the folder
WideScanDirForFiles(FilePath, Files, False, False, False, '*.txt');
FileName := FileName + ' (' + IntToStr(length(Files)) + ')';
end.With the first script if you forget adding files to the list, the result could be a chaos. (For example, "Folder (3)" with only 2 files inside)
But with this last script If there are non TXT files inside the folders, them will also be in the renamed folder. (Well, but I don't know if you wanted to separate the TXT from the other files)
My first attempt with the first script was with just folders and not files, and had as a result (0) for all folders.
This is why i had to use files instead of folders.
This new script is good now with just folders
Another question: how to also add "doc" files for searching. I have tried with adding '*.doc' after .txt but no luck. Same with OR; no luck. Maybe something like WideScanDirForFiles +=
I don't know pascal sorry ![]()
_________________
Well, I had to put the line SetLength(Files, 0); because it was remembering the last files and not counting from 0 each time.
Knowing that it doesn't reset itself automatically we can take advantage by adding after the first WideScanDirForFiles line, another similar, but changing only *.txt to *.doc
WideScanDirForFiles(FilePath, Files, False, False, False, '*.doc');It works but I don't know if there's a better solution...
I didn't try two WideScanDirForFiles !!!!!
Shame on me
I just add a delete rule in the first place to delete the old number so I didn't have duplicates.
Thanks for your help SafetyCar.
_________________
