#1 2010-05-04 11:50
narayan
Columns resize to equal width when auto-resize mode is OFF
when the "Auto-size table on change" option is deselected, all columns resize to equal width.
This looks weird, as even the narrowest columns (e.g. the "State" column) become too wide.
Desired:
Allow user to set the width of each individual column. ReNamer should remember those widths.
If ReNamer is restarted, the columns should have the same widths as the previous session.
#2 2010-05-20 23:52
Re: Columns resize to equal width when auto-resize mode is OFF
It is a legacy behavior dating all the way back to v1.00. I agree with the proposed behavior, added to the "to do" list.
#3 2010-05-21 12:32
ozzii
Thanks den4b for the "to do" list
_________________
