#1 2010-05-30 08:18
sm1rk
How to add renamed files NOT delete older
When iam trying to rename:
folder\folder2\file
to
folder_1\folder2_1\file_1
the program rename only first folder and can't find all other sub-folders cuz wrong path.
So i got error that success only 1 file and all other error. Result is:
folder_1\folder2\file
#2 2010-05-30 09:33
Re: How to add renamed files NOT delete older
Hi sm1rk, welcome.
folder\folder2\file
to
No wonder to me.
Since you rename the top most folder first, the sub folder has an new parent now:
"folder\folder2\file"
"folder_1\folder2\file"
so "folder2" is still searched under "folder" but is now to find under "folder_1".
To solve this click on the Folder column header to sort descending first to rename the deepest sub-folder first.
See our wiki > http://www.den4b.com/wiki/ReNamer:Renaming_folders
(thanks to Den4b for that demonstration)
Related posts:
http://www.den4b.com/forum/viewtopic.php?id=715
http://www.den4b.com/forum/viewtopic.php?pid=1466#p1466
http://www.den4b.com/forum/viewtopic.php?id=301
