It would be useful if each individual rule definition dialog pane had a one line field into which one could type a comment describing what the purpose of that line was. Then the rule display could look something like:
13 Replace first "Mon" with "-short-dayname-" replace short dayname info
14 Replace first "Tue" with "-short-dayname-" with a placeholder which
15 Replace first "Wed" with "-short-dayname-" we'll later replace by something else
Usually this would be more useful on the more complicated types of rule.
Hi Jeremy and welcome.
to be informed about what Denis is thinking about this idea
you may search the forum for 'comment' and you will find posts like this:
http://www.den4b.com/forum/viewtopic.php?id=379
http://www.den4b.com/forum/viewtopic.php?pid=1800#p1800
You should also know this:
The not easy story of the development, and the new way of things!
Then you may understood better if Denis is not answering immediately
