#1 2011-04-20 16:03
schmidty
Keep only first letter of each word
Hi everyone,
I have searched to see if my question has been answered, but no luck.  What I would like to do is rename files and keep only the first letter of each word. Example:
"middle arc inside stiffener plate - flat pattern.dxf"  would become "maisp-fp.dxf".  I assume this can be done with a script, (?!?) but I have no idea how to do it.  The spaces being removed isn't so important.  That much I can manage on my own! tongue
Thank you for any help you can give me!
By the way...what a great program!  I can't begin to add up all the time it has saved me!  Thanks den4b!!!!!!
#2 2011-04-20 20:18
Re: Keep only first letter of each word
Hi schmidty, welcome!
"maisp-fp.dxf".
DO:
Use an PascalScript (Wiki: HowTo use an PascalScript)
//get the first letter of all words and remove the rest, remove spaces too
//stefan
  Words : TStringsArray;
  FirstChars : WideString;
  i : Integer;
  //init, emtpy the var
  FirstChars:='';
  //split the FileName into words at spaces
  Words:=WideSplitString(WideExtractBaseName(FileName), ' ');
  //for each word in words do: get first char
  for i:=0 to Length(Words) - 1 do
      FirstChars := FirstChars + WideCopy(Words[i], 1, 1);
  //Compose the new FileName
  FileName := FirstChars + WideExtractFileExt(FileName);
Always test with copies of your files first.
HTH? big_smile
#3 2011-04-21 04:17
schmidty
Stefan,
Ich danke Ihnen sehr viel! big_smile  That script worked great!
I will read the "how-to" Wiki page you linked me to as well.  Since I know exactly what your script does, I can use that as a learning tool to help me learn Pascal.
Thanks again!
#4 2011-04-21 17:09
There is an alternative way for doing this, using RegEx rule:
1) RegEx: Replace expression "(\w)\w*" with "$1" (skip extension)
2) Replace: Replace all " " with "" (skip extension)
This will also convert "middle arc inside stiffener plate - flat pattern.dxf" into "maisp-fp.dxf".
Script is of course a lot more flexible and highly customizable!
