I was curious, is there a way to use Renamer to rename FOLDERS based on mp3 id3 tag info that is within the folder?
For example I would like my folders to be renamed as Artist - Album.
Can someone walk me through this if its possible?
It is possible via PascalScript
There is one example here:
http://www.den4b.com/wiki/ReNamer:Scrip … MasterFile
Adapted into your description it would be something like:
MASK = '*.mp3';
MasterFile: WideString;
function FindMasterFile(const Folder: WideString): WideString;
Files: TStringsArray;
Result := '';
SetLength(Files, 0);
WideScanDirForFiles(Folder, Files,
False, False, False, MASK);
if Length(Files) > 0 then
Result := Files[0];
MasterFile := FindMasterFile(FilePath);
if MasterFile <> '' then
FileName := CalculateMetaTag(MasterFile, 'ID3_Artist')
+ ' - ' + CalculateMetaTag(MasterFile, 'ID3_Album');
end.This script deletes the previous name, if you want to have it back take a look ate the differences between the code on the wiki an this one, on the line "FileName := ...".
Also for details on how to add folders to the file list you can check the help on the filter settings http://www.den4b.com/wiki/ReNamer:Filte … lters_menu
If you have doubts just ask ![]()
Wow! it worked! thanks you have no idea how much time you just saved me! THANKS!
