#1 2013-08-08 17:18
jackanapes
ISBN-10 to ISBN-13
Could anyone give a novice user some advice about how to convert a filename that uses an ISBN-10 to one that uses an ISBN-13 via ReNamer?
#2 2013-08-08 17:57
Re: ISBN-10 to ISBN-13
You have to find a common pattern to extract the ISBN-10 number from your file names to work on them (have some examples?),
then add a '978' as prefix, drop the last digit, and find an algorithm (or a command line tool) to calculate the new 'check digit' (right word?)
EDIT
I think over there such a algorithm can be found > http://www.hahnlibrary.net/libraries/isbncalc.html
ISBN (International Standard Book Number) is a unique number assigned to each book.
ISBN-10:
    • The number has 9 information digits and ends with 1 check digit.
    • Assuming the digits are "abcdefghi-j" where j is the check digit. Then the check digit is computed by the following formula:
j = ( [a b c d e f g h i] * [1 2 3 4 5 6 7 8 9] ) mod 11
ISBN-13:
    • The number has 12 information digits and ends with 1 check digit.
    • Assuming the digits are "abcdefghijkl-m" where m is the check digit. Then the check digit is computed by the following formula:
m = ( [a b c d e f g h i j k l] * [1 3 1 3 1 3 1 3 1 3 1 3] ) mod 10
Don't know if that is correct.
#3 2013-08-08 19:16
jackanapes
Thanks for the response, Stefan. The files are all named <ISBN-10>.xml. I presume renaming them to <ISBN-13>.xml will require Pascal Script or some regular expression voodoo, neither of which I am capable of myself, alas.
#4 2013-08-08 19:38
That's pretty fine (read: easy)
But how is the number formate? With or without hyphens? Have a few examples for us? Also needed to check the 'check digit'.
Yes. I will see if I find some time to write this script (but first here comes the night,... and then some job to do...)
Maybe a colleague here wants to jump in in the meantime?
Rather not, since we have to do the math too.
Don't worry. Perhaps you are able to help Denis in other ways? (means: read my signature big_smile)
Stay tuned.
#5 2013-08-08 21:21
jackanapes
I will certainly make a donation!
No dashes, so I'm working with filenames like 0262731312.xml, 026201212X.xml, and 0262134446.xml. (Desired output filenames for these would be 9780262731317.xml, 9780262012126.xml, and 9780262134446.xml, respectively.)
Thanks again!
#6 2013-08-09 08:30
Hmm, right now, I don't get it!  I can't calculate the check digit correctly.
vim 7 GE-PACKT
ISBN-10: 3826617819
ISBN-13: 978-3826617812
Learning the vi and vim Editors
ISBN-10: 059652983X
ISBN-13: 978-0596529833
sed and awk (Nutshell Handbooks)
ISBN-10: 1565922255
ISBN-13: 978-1565922259
Regular Expressions Pocket Reference
ISBN-10: 0596514271
ISBN-13: 978-0596514273
First test:
//http://isbn-information.com/isbn-information/the-13-digit-isbn.html
//http://isbn-information.com/isbn-information/check-digit-for-the-13-digit-isbn.html
//ISBN-10 =     382661781 9
//ISBN-13 = 978 382661781 2
 sISBN: String;
 iCheck: Integer;
  // Add your code here
  sISBN   := WideExtractBaseName(FileName);
  sISBN   := '978' + copy(sISBN, 1, length(sISBN)-1);
  iCheck  := StrToInt(sISBN);
  //    m  = ( [abcdefghijkl]  * [1313 1313 1313] ) mod 10
  iCheck  := (     iCheck      *   131313131313   ) mod 10;
  FileName := sISBN + IntToStr(iCheck)
0262731312.xml
3826617819.xml
059652983X.xml
1565922255.xml
0596514271.xml
I get:
9780262731313.xml
9783826617813.xml
9780596529833.xml
9781565922253.xml
9780596514273.xml
Second test:
 sISBN: String;
 iCheck,i,mul,tmp: Integer;
  mul      := 3;
  for i    := 1 to 12 do
    if mul  = 3 then
       mul := 1
    else
       mul := 3;
    tmp    := StrToInt(sISBN[i]);
    iCheck := iCheck + ( tmp * mul);
  showmessage('iCheck: '+ IntToStr(iCheck)+ ', Mod10: '+ IntToStr(iCheck mod 10) );
0262731312.xml
3826617819.xml
059652983X.xml
1565922255.xml
0596514271.xml
I get:
97802627313193.xml
978382661781211.xml
978059652983348.xml
978156592225469.xml
978059651427596.xml
I have to test some more....
#7 2013-08-09 09:17
@Stefan, I was curious about how this works and I took a look. I've seen somewhere that for finishing the checksum (after the loop) they do this iCheck := (10 - (iCheck mod 10)) mod 10;
Oh! and iCheck := 0 before starting the loop. You know... renamer remembers the last value, I usually fall on this too.
#8 2013-08-09 09:52
It seams as this is the part to check the calculated check digit if that math results in zero, then the check digit is correct.
But I already know the correct ISBN-13 number from getting it from a online book store.
I just can do the math myself (right now... at some point I will get it... but have to do other job first...)
Yes on my second test I will need that, thanks.
#9 2013-08-12 14:09
OK, it seams
1.) my first attempt with """m  = ( [abcdefghijkl]  * [1313 1313 1313] ) mod 10""" will not work anyway in PascalScript.
2.) I don't understand the whole 'mod' math not very well, but tests certify that if the result of the 'mod' operation is not equals zero,
(which would be a valid check sum then) then i have to do another math by subtracting my result from 10 to get the real check sum.
(if I only had been spend more attention at school time)
So i have adjusted my second script by adding this second decision (if not zero),
splitting the steps in separate operations, adjust the var name a bit and add some comments so maybe others can learn from this too.
This seams to work quite well. Please test yourself.
THE challenge:
0262731312.xml
026201212X.xml
0262134446.xml
9780262731317.xml
9780262012126.xml
9780262134446.xml
respectively.)
Stefan wrote:
vim 7 GE-PACKT
ISBN-10: 3826617819
ISBN-10: 059652983X
ISBN-10: 1565922255
ISBN-10: 0596514271
That means
0262731312.xml
026201212X.xml
0262134446.xml
3826617819.xml
059652983X.xml
1565922255.xml
0596514271.xml
9780262731317.xml
9780262012126.xml
9780262134446.xml
9783826617812.xml
9780596529833.xml
9781565922259.xml
9780596514273.xml
USE PascalScript:
 sISBN: String;
 i,dig,mul,prod,sum,checksum: Integer;
  //Get the ISBN-10 number from the file name:
  //here, the file name is ISBN only (have to be adjusted for other file names)
  //Adjust the ISBN-10 to become a ISBN-13:
  //drop last digit (the ISBN-10 check sum)
  sISBN    := copy(sISBN, 1, length(sISBN)-1);
  //add 978 (or 979) for ISBN-13 format
  sISBN    := '978' + sISBN;
  //calculate the ISBN-13 check sum (or: check digit)
  sum           := 0;
  mul           := 3;
  for i         := 1 to 12 do
        if mul   = 3 then
           mul  := 1
        else
           mul  := 3;
        dig     := StrToInt(sISBN[i]);
        prod    := (dig * mul);
        sum     := sum + prod;
  checksum      := sum mod 10;
  if checksum   <> 0 then
     checksum   := 10 - checksum;
  //compose new FileName:
  FileName      := sISBN + IntToStr(checksum)
(OK, we don't have to really multiply the digit by 1 and can rearrange the code to drop this,... but I enjoy it works, so I don't care right now tongue)
See our wiki for how to use PascalScript in den4b ReNamer >>> http://www.den4b.com/wiki/ReNamer:Rules:PascalScript
HTH? big_smile (and works roll )
#10 2013-08-13 16:35
I recall similar calculations in a script for calculating the checksum digit for the EAN-13 barcode: ReNamer:Scripts:EAN-13.
When you are done with your script, you should put it on the wiki as well.
