#1 2014-10-22 10:06
user108
Is it possible to change date format from dd.mm.yyyy to yyyy-mm-dd?
Is it possible to rename files in the following way:
BVS Bg 04.11 - Peterburg 30.10.2010  -->  BVS Bg 04.11 - Peterburg 2010-10-30
BVS Bg 04.13 - Riga 14.10.2011         -->   BVS Bg 04.13 - Riga 2011-10-14
BVS Bg 02.15 - Minsk 23.09.97           -->   BVS Bg 02.15 - Minsk 97-09-23
#2 2014-10-22 15:28
Re: Is it possible to change date format from dd.mm.yyyy to yyyy-mm-dd?
Yes, you can do this with a RegEx rule:
Replace expression "(\d{1,2})\.(\d{1,2})\.(\d{2,4})" with "$3-$2-$1"
#3 2014-10-22 19:10
user108
Thank you very much! It works.
Please help me one more time. What about the following two rules?
1)  BVS Bg 13.28 - Riga 07.92               -->   BVS Bg 13.28 - Riga 92-07
2)  BVS Bg 13.08-13 - Moscow 05.1994  -->   BVS Bg 13.08-13 - Moscow 1994.05
Best regards,
Denis
#4 2014-10-24 07:00
You can find out that yourself, see
\. ==> means: match a literal dot
\d{2,4} ==> means: match two till four digits
(...) ==> the parentheses means: capture what is matched, for reuse with $1 sign ($1,$2,... counts () from the left)
In your case, you have to add a trailing "$" sign, to match the digits only at the end of your string (name)
See http://www.den4b.com/wiki/ReNamer:Regular_Expressions  for more.
RegEx rule:
(http://www.den4b.com/wiki/ReNamer:Rules:RegEx)
Expression: (\d{1,2})\.(\d{2,4})$
Replace:     $2-$1
#5 2014-10-24 21:49
user108
Thank you, Stefan!
Best regards,
Denis
#6 2016-02-08 18:40
NWH6
Some files sent to me contain 2 dates in the filename. They were formatted in dd-mm-yyyy-dd-mm-yyyy, I wanted them as yyyymmdd-yyyymmdd!
Found this and it's great. And the one entry does both dates - I'm still not sure how it works but it does.
Thank you for a great product.
“You will do foolish things, but do them with enthusiasm.” - Colette
#7 2016-02-09 02:05
You should check out the new Reformat Date rule, which is available in the latest development version.
