I have 10 images with different 'Date Taken' dates, like
After my first modifications:
1) Delete: Delete from Position 1 until the End (skip extension) (Remove original name)
2) Insert: Insert ":EXIF_Date: - " as Prefix (skip extension)
3) Serialize: Serialize Incremental from 1 step 1 repeat 1 as Suffix (before extension)
I get 001...010:
But this is what i really want to get:
001...005 + 001...005
How to get it?
Many thanks...
EDIT to add:
2017-05-27 09:32:40
den4b    Administrator
   Re: Serialize - Reset if file (name) changes
     Option "Reset if file name changes" has been added to the Serialize rule in ReNamer v6.7.0.1 Beta.
Try this:
4) Delete: Delete from Position 14 until the End (remove your serialisation)
to get:
2013-07-06 -
2013-07-06 -
2013-07-06 -
2013-08-07 -
2013-08-07 -
2013-08-07 -
5) Add below PascalScript
to get:
PascalScript:
//Add serialize number but reset counter if file name change
  CurrOrgFileName, LastOrgFileName, SerialString, LastOrgFileNameStorage: WideString;
  SerialNumber: Integer;
   LastOrgFileName := LastOrgFileNameStorage;
   CurrOrgFileName := WideExtractFileName(FileName);
   LastOrgFileNameStorage := CurrOrgFileName;
   //If FileName still the same then
   //increase SerialNumber, else reset to 1:
   If (CurrOrgFileName = LastOrgFileName) Then
             SerialNumber := SerialNumber+1
   else
             SerialNumber := 1;
   //Pad SerialNumber to wanted length:
   SerialString := IntToStr(SerialNumber);
   While (Length(SerialString) < 3) Do
              SerialString := '0' + SerialString;
   FileName := CurrOrgFileName + SerialString + WideExtractFileExt(FilePath);
end.(Read our wiki how to use an script >> http://www.den4b.com/wiki/ReNamer:Rules:PascalScript )
You can also skip your rule #3.
 ReNamer will add his own numbering, if you enable "Fix conflicting new names". (http://www.den4b.com/wiki/ReNamer:Menus … tions_menu)
For my rule #4 adjust then the amount to delete.
