Add numbering to same PART OF name
Add serialization but reset if a special part of the file name changes, like here the day part:
Once I have this file names:
IMG_101_2015-05-15 <
IMG_102_2015-05-15
IMG_103_2015-05-17 <
IMG_104_2015-05-18 <
IMG_105_2015-05-19 <
IMG_106_2015-05-19
IMG_107_2015-05-19I would like to rename at the end as follows:
IMG_101_2015-05-15_001 <-- #1 for day 15
IMG_102_2015-05-15_002
IMG_103_2015-05-17_001 <-- #1 for day 17
IMG_104_2015-05-18_001 <-- #1 for day 18
IMG_105_2015-05-19_001 <-- #1 for day 19
IMG_106_2015-05-19_002
IMG_107_2015-05-19_003Apparently what I’m trying to do, is add an incremental number that restarts on each day.
Even if a day has a single image, the name must have a number.Is there a way to do that?
Thanks in advance!!
IMG_101_2015-05-15
IMG_102_2015-05-15
IMG_105_2015-05-19
IMG_106_2015-05-19
IMG_101_2015-05-15_001 <-- 1 for day 15
IMG_105_2015-05-19_001 <-- 1 for day 19
Try this den4b ReNamer PascalScript
(Read our wiki how to use an script >> http://www.den4b.com/wiki/ReNamer:Rules:PascalScript )
Note: for name differ from your example names, you have to adjust the RegEx expression to extract the NamePart 1 and 2.
  oldName, NamePart1, NamePart2, strNumber, Storage: WideString;
  Number: Integer;
   oldName := WideExtractFileName(FileName);
   //Match on "IMG_101_2015-05-15" > "IMG_101_" + "2015-05-15"
   NamePart1 := ReplaceRegEx(oldName, '(IMG_\d\d\d_)(.+)', '$1', False, True);
   NamePart2 := ReplaceRegEx(oldName, '(IMG_\d\d\d_)(.+)', '$2', False, True);
   If (NamePart2 = Storage) Then Number := Number+1 else Number := 1;
   strNumber := IntToStr(Number);
   If (Length(strNumber) <2) Then strNumber := '0'+ strNumber;
  FileName := NamePart1 + NamePart2
              + '_' + strNumber
  Storage := NamePart2;
