#1 2015-07-04 23:23
polkadot
Regular expressions not working
For some reason, regular expressions won't work for me. I've used them before, but now... nada. I uninstalled 6.1 and installed 6.2, but it didn't make a difference. Any ideas? It's just so strange that it suddenly stopped working.
#2 2015-07-04 23:42
Re: Regular expressions not working
Can you provide expressions that don't work for you, together with examples of expected results?
#3 2015-07-05 00:26
polkadot
I first tried for my files, then when it didn't work, I tried the examples in the help files. Namely this one (though I started with all lowercase)...
den4b(dot)com/wiki/ReNamer:Regular_Expressions#Upper_case_and_lower_case_manipulations
Input: test example
Find: (.+) (.+)
Replace: \U$1 $2
Expected Result: TEST example
Actual result: No change -- nothing turned red under the New Name column
Input: test example
Find: (.+) (.+)
Replace: mmmm
Expected Result: mmmm
I hadn't tried anything else, but because you asked, I tried these...
Input: test example
Find: te*
Replace: mmmm
Result: mmmm (as expected!)
Input: test example
Find: te?
Replace: mmmm
Result: mmmmt example (as expected!)
Input    : test example
Find: test (.+)
Replace: $1
Expected Result: example (I think?)
Input: test example
Find: (\w+) (\w+)
Replace: mmmm
Does that give you enough info? Anything else I should try?
#4 2015-07-05 02:05
All of your listed examples seem to work fine here.
Have you applied the rules, by clicking the Preview button (in case you have auto-preview disabled)? Do you have any other rules that might conflict?
Please provide a screenshot and a preset file. Also, try manually deleting ReNamer.ini file (that will remove all your settings).
Make sure you download the official version of ReNamer from here:
http://www.den4b.com/?x=products&product=renamer
#5 2015-07-05 02:55
polkadot
Yep, I downloaded ReNamer from den4b(dot)com.
I have "auto preview on change of rules configuration" checked. When I ran the tests, I clicked the preview button, too, just to be sure.
Only one rule was in use, so no conflict there.
I searched for renamer.ini but couldn't find it. I only have renamer.exe and various renamer(xx).po files.
Where's the preset file and what's it called?
I've uploaded three screenshots.
Thanks for your help! smile
#6 2015-07-05 02:58
polkadot
FWIW, I made a new file (test example.xlsx) and tried renaming that one. Same results.
#7 2015-07-05 04:18
"A picture is worth a thousand words"
Try using RegEx rule, instead of Replace! wink
#8 2015-07-05 05:05
polkadot
Hooray for screen caps! I thought I had used those expressions before in Replace, but apparently I had actually used RegEx. Clearly my memory is not to be trusted. tongue Thanks much!
