#1 2015-10-14 09:36
eric91
Roman To Arabic in filename conversion
in musical files, i have often someting like
"Variation XV Canone alla Quinta.flac"
Such roman number does'nt sort correctly so i wrote a VBS function which run and convert it to Pascal.
function RomanToArabic(Roman:string):string;
// limited to roman string <255 car !!
   idx:byte;
   total, valPrec, valCourante:Word;
   ValPrec:=65535;
	for i:=1 to Length(Roman) do
		case roman[idx] of
		  'M' : valCourante:=1000;
		  'D' : valCourante:=500;
		  'C' : valCourante:=100;
		  'L' : valCourante:=50;
		  'X' : valCourante:=10;
		  'V' : valCourante:=5;
		  'I' : valCourante:=1;
		total:=total+valcourante;
		if valcourante>valprec then valprec:=valprec - (2*valprec);
		valprec:=valcourante;
	result:=IntToStr(total);
But my problem now is to use it.
I know to use a regexp to to extract a $x value but i don't know how to collect this value, how to apply the function and how to insert the result back to the filename.
An idea can be to allow the possibility to use $1...$9 as parameters for users functions.
If you can help me it would be nice.
Regards
Eric
#2 2015-10-14 12:30
Re: Roman To Arabic in filename conversion
Hi and welcome Eric!
I don't know.... but here are some hints:
WIKI wrote:
http://www.den4b.com/wiki/ReNamer:Pascal_Script
In Pascal Script, ReNamer has defined the FileName variable to represent the New Name of the File.
Therefore, in your script, you will have to manipulate this variable to change the filename.
http://www.den4b.com/wiki/ReNamer:Pasca … g_Handling
function SubMatchesRegEx(const Input, Find: WideString;const CaseSensitive: Boolean): TStringsArray;
My guess is something like this idea may be an start:
(non tested script)
   Parts: TStringsArray;
   Parts := SubMatchesRegEx(FileName , '(.+ )([MDCLXVI]+)( .+)', TRUE);
   If (Length(Parts) = 3)Then
      // WideShowMessage(Parts[0] + Parts[1] + Parts[2]);
      FileName := Parts[0] + RomanToArabic(Parts[1]) + Parts[2];
      Exit;
   End;
HTH?
#3 2015-10-14 12:41
OK, I didn't get peace, so here is my tested script:
"Variation 15 Canone alla Quinta.flac"
USE PascalScript (http://www.den4b.com/wiki/ReNamer:Rules:PascalScript)
Change Roman numbers to arabic:
TO:    "Variation 15 Canone alla Quinta.flac"
// Helper Function:
(* limited to roman string <255 car !! *)
   idx:byte;
   ValPrec:=65535;
    for idx:=1 to Length(Roman) do
        case roman[idx] of
// Main script:
      Exit;
   End;
HTH?
#4 2015-10-14 15:39
eric91
Hello Stefan,
thanks for help and bonus : Now I know the HTH acronym smile:)
Thats works perfectly.
As idea of evolution, i imagine a custom string function library on a side and on the regex rule tab , in the replace line, the ability to replace a subexpression by function(subexpression).
I use very often Renamer and am happy to have bought it.
Regards
Eric
#5 2015-10-14 22:10
I went with a bit of an old fashioned and hardcore approach - manually parsing, extracting and replacing all roman numerals. The result is a more flexible way than RegEx, by allowing roman numerals to appear at the start or end of name, surrounded by punctuation, etc.
Example: "VI test (M) test-XI.txt" will be converted to "6 test (1000) test-11.txt"
WARNING: In this code the RomanToArabic function is the one that you have provided! Beware that it does not handle least-significant-order roman numerals correctly, i.e. IX and XI both get converted to 11, while it should be 9 and 11, respectively.
  AllRomanDigits = 'MDCLXVI';
function RomanToArabic(const Roman: String): String;
  i: byte;
  total, valPrec, valCourante: Word;
  ValPrec:=65535;
		case roman[i] of
function IsWideCharWordBreak(const WC: WideChar): Boolean;
  Result := IsWideCharSpace(WC) or IsWideCharPunct(WC);
function FindRomanNumber(const Subject: WideString;
  out RomanNumber: WideString; var NextPosition: Integer): Boolean;
  Started: Boolean;
  Result := False;
  Started := (NextPosition = 1);
  RomanNumber := '';
  while NextPosition <= Length(Subject) do
    if IsWideCharWordBreak(Subject[NextPosition]) then
      if Length(RomanNumber) > 0 then
        Break;
      Started := True;
    end
    else if Started then
      if WidePos(Subject[NextPosition], AllRomanDigits) > 0 then
        RomanNumber := RomanNumber + Subject[NextPosition]
      else
        Started := False;
        RomanNumber := '';
    NextPosition := NextPosition + 1;
  Result := WideLength(RomanNumber) > 0;
procedure ReplaceRomanDigits(var S: WideString);
  RomanNumber, ArabicNumber: WideString;
  NextPosition, RomanNumberPos: Integer;
  NextPosition := 1;
  while FindRomanNumber(S, RomanNumber, NextPosition) do
    ArabicNumber := RomanToArabic(RomanNumber);
    RomanNumberPos := NextPosition - WideLength(RomanNumber);
    WideDelete(S, RomanNumberPos, WideLength(RomanNumber));
    WideInsert(ArabicNumber, S, RomanNumberPos);
    NextPosition := NextPosition - WideLength(RomanNumber) + WideLength(ArabicNumber);
  BaseName: WideString;
  ReplaceRomanDigits(BaseName);
  FileName := BaseName + WideExtractFileExt(FileName);
#6 2015-10-15 00:28
eric91
thanks for this code. I will look it further later to try to full understand it. (The last time i do Turbo Pascal was in 1984.)
I try my vbs code and it work. In fact, i do a mistake when I convert VBS to Pascal.
The good code is a modification after the test.
replace :
by
if valcourante>valprec then total:=total - (valprec+valprec);
Sorry roll.
the good code with all your modifications is :
  i: byte;
  ValPrec:=65535;
		case roman[i] of
		total:=total + valCourante;
		if valCourante > valPrec then total:=total - (valPrec + valPrec);
		valPrec:=valCourante;
  Started: Boolean;
  Result := False;
  RomanNumber := '';
        Break;
      Started := True;
    end
      else
        Started := False;
        RomanNumber := '';
  NextPosition := 1;
This code has some limits and "unreal" roman numbers are interpreted like IXI =10
I test (in VBS) RomanToArabic from 1 to 4000 with the ArabicToRoman (den4b.com/forum/viewtopic.php?id=828) and it works till 4000 where ArabicToRoman produce M(V) but RomanToArabic expect MMMM.
I try "MMMMDCCCLXXXVIII" which give 4888 (Wikipedia : fr.wikipedia.org/wiki/Num%C3%A9ration_romaine)
Eric
