#1 2024-03-11 11:13
psb_24
replace / change position
Hi to everyone,
I have learned that there are regular expressions.
I'm just not sure if it's possible to solve my problem with it.
Current file name:
First name(space!!!)Last name(space)- everything after the hyphen should remain as it is
Desired result:
Last name,(space)first name(space)- everything after hyphen as in original filename.
Is it possible to implement something here with regular expressions and if so, how?
Sure, double names etc. will cause problems, I can live with that.
kind regards
Peter
#2 2024-03-11 15:23
eR@SeR
Re: replace / change position
Hello Peter,
I guess this is what you were looking for:
Swap name and surname, with 2 and 3 words
P.S. You can search forum before posting. Someone might asked the same or similar question already.
Cheers! smile
#3 2024-03-11 19:48
psb_24
Hi eR@SeR,
this is something I have already found - but did not help to me. Possibly input error/user error
#4 2024-03-12 10:06
psb_24
solved - user error
big_smile
