#1 2025-06-20 03:26
ActingPrimeMinister
Serializing page count as a prefix, continuing from previous files
Let's say I have 400 pdfs, all of differing page count. I have added a number to the bottom right corner of each page of each file. For example, in the bottom right hand corner, File1 has 000001 on pg. 1, 000002 on pg. 2, and so on. For the sake of clarity, lets say these are the four files I need renamed along with the numbers that have been added to each page of each file.
File1 - 000001-000005
File2 - 000006-000027
File3 - 000028-000032
File4 - 000033-000103
Is there a way to build a script that will add each file's portion of the range as a prefix to the original file name? From the above example, the file names File1, File2, File3, File4 would become
000001-000005 File1
000006-000027 File2
000028-000032 File3
000033-000103 File4
You can see how long this would take to do manually for 400 files. I can't simply use the pagecount, because each prefix needs to carry over from the end of the file immediately before it alphabetically. If you can help me out on this, you could save me many hours per week and I would be eternally thankful.
Thanks!
#2 2025-06-20 14:19
Re: Serializing page count as a prefix, continuing from previous files
To paraphrase it slightly, you want to serialise your files with a cumulative page count range. Correct?
Yes, that's possible, using the Pascal Script rule with the help from a 3rd party utility for extracting PDF page counts.
First, download Xpdf command line tools: https://www.xpdfreader.com/download.html
You'll just need the "pdfinfo.exe" tool from the downloaded archive. You can install this tool anywhere you like, even into ReNamer's folder.
Then, use this script in a Pascal Script rule:
  PdfInfoExe = 'pdfinfo.exe';
  Pattern = '[\n\r]Pages:\s+(\d+)\b';
  PadNumbersToLength = 6;
function ExtractPdfPageCount(const Path: WideString): Integer;
  Command: WideString;
  Output: String;
  Matches: TWideStringArray;
  Result := 0;
  Output := '';
  Command := PdfInfoExe + ' "' + Path + '"';
  if ExecConsoleApp(UTF8Encode(Command), Output) = 0 then
    Matches := SubMatchesRegEx(UTF8Decode(Output), Pattern, False);
    if Length(Matches) > 0 then
      Result := StrToInt(Matches[0]);
function PadZeros(const Number: Integer; MaxLength: Integer): String;
  Result := IntToStr(Number);
  while Length(Result) < MaxLength do
    Result := '0' + Result;
  Initialized: Boolean;
  TotalPageCount, PageCount: Integer;
  if not Initialized then
    Initialized := True;
    TotalPageCount := 0;
  PageCount := ExtractPdfPageCount(FilePath);
  if PageCount > 0 then
    FileName :=
      PadZeros(TotalPageCount + 1, PadNumbersToLength) + '-' +
      PadZeros(TotalPageCount + PageCount, PadNumbersToLength) + ' ' +
      FileName;
    TotalPageCount := TotalPageCount + PageCount;
You may need to adjust the "PdfInfoExe" constant to point it to the correct location of the "pdfinfo.exe" tool.
If that helps, consider supporting the development by purchasing a Pro license.
#3 2025-06-20 17:19
ActingPrimeMinister
Thanks so much. Unfortunately I am not able to install this third party software. Is there no way to pull page count data without third party software? That seems almost too shortsighted to be true, but I suppose Windows has done worse things before.
#4 2025-06-21 00:03
There is no installation required. It is simply a ZIP archive.
You can unpack it anywhere you like, even on your on Desktop, and then update the path in the script accordingly.
