#1 2025-09-14 14:10
geniusnet132
Capital letters except inside parentheses or brackets
I want to change the initial capital letters of each word in a batch of files, but without changing what is inside parentheses or brackets.
Example:
BEFORE- [Superman] the death of superman (deluxe edition)
AFTER- [Superman] The Death Of Superman (deluxe edition)
Best regards and thank you for your help.
#2 2025-09-15 12:43
eR@SeR
Re: Capital letters except inside parentheses or brackets
You can use Pascal script rule. Based on one provided example pattern, this script should work:
  BaseName, Prefix, Middle, Suffix: WideString;
  PosStart, PosEnd: Integer;
  // Extract content inside square brackets
  PosStart := Pos('[', BaseName);
  PosEnd := Pos(']', BaseName);
  if (PosStart > 0) and (PosEnd > PosStart) then
    Prefix := Copy(BaseName, PosStart, PosEnd - PosStart + 1);
    Middle := Copy(BaseName, PosEnd + 1, Length(BaseName));
  end
  else
    Prefix := '';
    Middle := BaseName;
  // Extract content inside parentheses at the end
  PosStart := Pos('(', Middle);
  PosEnd := Pos(')', Middle);
    Suffix := Copy(Middle, PosStart, PosEnd - PosStart + 1);
    Middle := Copy(Middle, 1, PosStart - 1);
  end
  else
    Suffix := '';
  // Capitalize the middle part
  Middle := WideCaseCapitalize(Trim(Middle));
  // Reconstruct the filename
  FileName := Trim(Prefix + ' ' + Middle + ' ' + Suffix) + WideExtractFileExt(FileName);
What this script does:
- extracts the part inside brackets [] () and keeps it unchanged
- capitalizes everything else using WideCaseCapitalize function
- reassembles the filename with proper spacing
Before:
[SUPERMAN] the death of superman (DELUXE edition)
[superman] THE DEATH OF SUPERMAN (deluxe Edition)
After:
[SUPERMAN] The Death Of Superman (DELUXE edition)
[superman] The Death Of Superman (deluxe Edition)
P.S. You can modify script using AI, if required.
#3 2025-09-18 22:48
geniusnet132
Extremely grateful
