#1 2026-04-18 15:41
blanc
Rename a file after another file
In a folder there are one src and one txt files. How can I rename the txt file so that it copies src file name?
Before renaming: today.src and tomorrow.txt
After renaming: today.src and today.txt
#2 2026-04-18 16:24
Re: Rename a file after another file
You'll need to use the Pascal Script rule for this.
This script will find the first file matching the specified mask (MASTER_FILE_MASK) located in the same directory, and will use its base name as the new name for the file in the renaming list.
  MASTER_FILE_MASK = '*.src';
function FindFirstFile(const Folder, FileMask: WideString): WideString;
  Files: TWideStringArray;
  Result := '';
  SetLength(Files, 0);
  WideScanDirForFiles(Folder, Files, False, False, False, FileMask);
  if Length(Files) > 0 then
    Result := Files[0];
  MasterFile: WideString;
  MasterFile := FindFirstFile(WideExtractFileDir(FilePath), MASTER_FILE_MASK);
  if Length(MasterFile) > 0 then
    FileName := WideExtractBaseName(MasterFile) + WideExtractFileExt(FilePath);
P.S. This script now has a permanent place in the Pascal Script Library.
