Pascal Script: Library
This page provides curated, ready-to-use scripts for common renaming tasks and integrations with third-party tools. Each script can be copied directly into the Pascal Script rule and adapted by adjusting the constants at the top.
Additionally, the User Forum is a valuable source of community-contributed scripts covering a wider range of use cases — though as with any user-contributed content, scripts should be reviewed and tested carefully before use.
Using console applications
Several scripts in this library work by running an external command-line tool, capturing its output, and parsing the result to produce a new filename. This is done with the ExecConsoleApp function:
ExecConsoleApp(const Command: String; out Output: String): Cardinal
It executes the command string, blocks until the program finishes, captures everything written to standard output into Output, and returns the program's exit code. An exit code of 0 indicates success for all tools covered here.
Console applications typically write output using the OEM character encoding (the legacy DOS code page). Unless the tool provides its own UTF-8 output option, convert the output with OemToWide before using it in a filename:
UnicodeOutput := OemToWide(Output);
Always enclose both the executable path and the file path in double quotes within the command string, to handle spaces in paths correctly:
Command := '"' + ExePath + '" [options] "' + FilePath + '"';
ExifTool
ExifTool is a powerful, actively maintained tool for reading and writing metadata in a very wide range of file formats, including JPEG, RAW (CRW, CR2, NEF, ARW, and many others), HEIF, TIFF, PNG, video files, and more. It supports EXIF, IPTC, XMP, and many vendor-specific tag namespaces.
Setup
- Download the ExifTool Windows package and extract it into ReNamer's folder.
- The archive contains a file named
exiftool(-k).exe. Rename it toexiftool.exebefore use. The(-k)suffix causes the tool to wait for the user to press Enter before closing — ReNamer cannot send that input, so the application will freeze if this step is skipped.
Script
The script below renames files using the Date/Time Original EXIF tag. Adjust the TAG constant to extract any other tag.
EXE = 'exiftool.exe -t -charset filename=utf8';
TAG = 'Date/Time Original' + #9 + '(.*?)[\r\n]';
Command, Output: String;
Matches: TWideStringArray;
Command := EXE + ' "' + FilePath + '"';
Matches := SubMatchesRegEx(Output, TAG, False);
if Length(Matches) > 0 then
FileName := Matches[0] + WideExtractFileExt(FileName);
The -t flag produces tab-delimited output (TagName<tab>Value), which the TAG regex captures reliably. #9 is the tab character. The -charset filename=utf8 flag tells ExifTool to interpret filenames as UTF-8, which is necessary for Unicode paths.
Discovering available tags
Run exiftool.exe <file> from the command line to list all tags and their values for any given file. Paste the tag name into the TAG constant, replacing the example.
The raw tag value is used as the filename and may contain characters that are invalid in Windows filenames (colons are common in date strings, for example). Add a Replace or Clean Up rule after the Pascal Script rule to sanitise the result if needed.
Tested with ReNamer 7.9 and ExifTool 12.58.
Exiv2
Exiv2 is a lightweight open-source library for reading and writing EXIF, IPTC, and XMP metadata from JPEG and RAW image formats (including CRW, CR2, and many others).
Setup
- Download the Exiv2 Windows package and extract its
binfolder contents into ReNamer's folder. The required file isexiv2.exealong with any DLLs it ships with. - Exiv2 is distributed in several build variants with different runtime dependencies. If you see errors about missing DLLs, install the matching Microsoft Visual C++ Redistributable.
Script — extract any tag
The script below extracts the camera model (Exif.Image.Model) and prepends it to the filename. Change the TAG constant to extract any other Exiv2 key.
TAG = 'Exif.Image.Model';
EXECUTABLE = 'exiv2.exe';
PARAMETERS = '-Pt -K ' + TAG;
UnicodeOutput: WideString;
Command := '"' + EXECUTABLE + '" ' + PARAMETERS + ' "' + FilePath + '"';
UnicodeOutput := WideTrim(OemToWide(Output));
if UnicodeOutput <> '' then
FileName := UnicodeOutput + ' ' + FileName;
The -Pt flag prints the tag value only (no label or formatting). The -K flag filters output to a specific key, so Output contains just the value followed by a newline. OemToWide handles the encoding conversion.
Script — extract and reformat EXIF date
EXIF date values are formatted as yyyy:mm:dd hh:mm:ss, which contains colons that are illegal in Windows filenames. This variant extracts the date and reformats it cleanly. Adjust DATE_TAG and DATE_FORMAT as needed.
DATE_TAG = 'Exif.Photo.DateTimeOriginal';
DATE_FORMAT = 'yyyy-mm-dd hh.nn.ss';
DateTime: TDateTime;
Command := '"' + EXECUTABLE + '" -Pt -K ' + DATE_TAG + ' "' + FilePath + '"';
if TryScanDateTime('yyyy:mm:dd hh:nn:ss', Output, DateTime) then
FileName := FormatDateTime(DATE_FORMAT, DateTime) + WideExtractFileExt(FileName);
TryScanDateTime parses the EXIF date string according to the format pattern. If parsing fails — for example, because the tag is absent — the script leaves FileName unchanged without raising an error.
Run exiv2.exe -pa <file> to list all metadata keys and their values for any given file. Keys follow the dotted namespace format (Exif.Image.Model, Iptc.Application2.Headline, etc.).
Tested with ReNamer 7.9 and Exiv2 0.27.2.
MediaInfo
MediaInfo extracts technical and descriptive metadata from a wide variety of audio and video formats, including MP4, MKV, AVI, MP3, FLAC, and many others. It can report codec names, duration, bitrate, encoding date, track titles, and more.
Setup
- Download the MediaInfo CLI package (the command-line interface version, not the GUI) and extract it anywhere on your system.
- Set the
MediaInfoExeconstant in the script to the full path of theMediaInfo.exeexecutable.
Script
The script below renames files using the Encoded_Date tag. Adjust OutputParameter to extract any other supported tag.
MediaInfoExe = 'C:\Tools\MediaInfoCLI\MediaInfo.exe';
OutputParameter = 'General;%Encoded_Date%';
Command: WideString;
Output: String;
Command :=
'"' + MediaInfoExe + '"' +
' --output="' + OutputParameter + '"' +
FileName := WideTrim(OemToWide(Output)) + WideExtractFileExt(FilePath);
The --output parameter uses a template format: Section;%TagName%. The General section covers file-level properties; other sections include Video, Audio, Text, and Image. For example, 'Video;%Format%' extracts the video codec name.
Use these built-in help commands from the command line to explore available tags:
MediaInfo.exe --Help— general help.MediaInfo.exe --Help-Output— documentation for the output template format.MediaInfo.exe --Info-Parameters— full list of supported tag names.
Tested with ReNamer 7.9 and MediaInfo 26.01.
Xpdf
Xpdf provides a suite of PDF processing tools. The pdfinfo.exe utility extracts document properties such as Title, Author, Subject, Creator, and creation date from PDF files.
Setup
- Download Xpdf tools and copy
pdfinfo.exeinto ReNamer's folder.
Script
The script below renames PDF files using their Title tag. Change the TAG constant to extract any other property.
EXE = 'pdfinfo.exe -enc UTF-8';
TAG = 'Title\s*\:\s*(.*?)[\r\n]';
The -enc UTF-8 flag instructs pdfinfo.exe to write its output in UTF-8, so no OemToWide conversion is needed. The TAG regex captures the value following the property label and colon; replace Title in the pattern to target a different property.
Run pdfinfo.exe <file> from the command line to list all properties available for a given PDF. Common tags include Author, Subject, Keywords, Creator, CreationDate, and ModDate.
Tested with ReNamer 7.9 and Xpdf tools 4.01.01.
TrID
TrID identifies the true type of a file by analysing its binary content, independently of the existing extension. It is useful for correcting mislabelled files or assigning extensions to files that have none.
Unlike the other tools in this library, TrID is integrated via DLL import rather than as a console application. See Importing external functions in the Examples article for background on this mechanism.
Unicode limitation: TrID library processes file paths as ANSI strings. Files with non-ASCII characters in their paths will not be handled correctly and are therefore skipped by the script.
Setup
Download and place both files into ReNamer's folder:
TrIDLib.dll— the identification library. See the TrIDLib product page for version history and additional notes.TrIDDefs.TRD— the file type definitions database. TrID's identification quality depends on using an up-to-date database file, so re-download it periodically to pick up newly added file types.
Script
The script identifies the file type, applies a confidence cutoff of 20% to filter low-confidence matches, and sets the extension to the best match (or multiple candidates separated by | when several types score above the cutoff). It loads the definitions database once at initialisation and errors if the database file is missing.
{ TrID — file type detection by content }
// Minimum confidence percentage for the detected
// file extensions to be included in the result.
TargetConfidenceCutoff = 20;
function TridLoadDefsPack(szPath: PChar): Integer;
external 'TrID_LoadDefsPack@TrIDLib.dll stdcall';
function TridSubmitFileA(szFileName: PChar): Integer;
external 'TrID_SubmitFileA@TrIDLib.dll stdcall';
function TridAnalyze: Integer;
external 'TrID_Analyze@TrIDLib.dll stdcall';
function TridGetInfo(lInfoType: Integer; lInfoIdx: Integer; sBuf: PChar): Integer;
external 'TrID_GetInfo@TrIDLib.dll stdcall';
TRID_GET_RES_NUM = 1;
TRID_GET_RES_FILEEXT = 3;
TRID_GET_RES_POINTS = 4;
TRID_BUFFER_SIZE = 4096;
function GetExtensions(ConfidenceCutoff: Integer): WideString;
Buffer, Extension: String;
I, NumMatches, NumPoints, TotalPoints: Integer;
Result := '';
SetLength(Buffer, TRID_BUFFER_SIZE);
NumMatches := TridGetInfo(TRID_GET_RES_NUM, 0, PChar(Buffer));
if NumMatches > 0 then
TotalPoints := 0;
// Count total points for all matches
for I := 1 to NumMatches do
TotalPoints := TotalPoints + TridGetInfo(TRID_GET_RES_POINTS, I, PChar(Buffer));
// Iterate through all matches
// Check if a match passes the minimum confidence level
NumPoints := TridGetInfo(TRID_GET_RES_POINTS, I, PChar(Buffer));
if (NumPoints * 100 / TotalPoints) >= ConfidenceCutoff then
// Include the detected file extension
if TridGetInfo(TRID_GET_RES_FILEEXT, I, PChar(Buffer)) > 0 then
Extension := LowerCase(String(PChar(Buffer)));
if (Length(Extension) > 0) and (Pos(Extension, Result) = 0) then
if Length(Result) > 0 then Result := Result + '|';
Result := Result + Extension;
// Normalize the delimiter between file extensions
Result := WideReplaceStr(Result, '/', '|');
Initialized: Boolean;
AppPath, FileExtensions: WideString;
if not Initialized then
Initialized := True;
AppPath := WideExtractFilePath(GetApplicationPath);
if TridLoadDefsPack(AppPath) = 0 then
Error('TrID database file not found in the application folder.');
// Skip Unicode filenames, because TrID library only works with ANSI filenames
if FilePath <> UTF8Decode(WinCPToUTF8(UTF8ToWinCP(UTF8Encode(FilePath)))) then
Exit;
if TridSubmitFileA(PChar(FilePath)) <> 0 then
if TridAnalyze <> 0 then
FileExtensions := GetExtensions(TargetConfidenceCutoff);
if FileExtensions <> '' then
FileName := WideStripExtension(FileName) + '.' + FileExtensions;
TridLoadDefsPack is called once and receives the application folder path, from which it locates TrIDDefs.TRD. TridSubmitFileA submits the file for analysis and TridAnalyze runs the identification. GetExtensions collects all results above the confidence cutoff, converting them to lowercase and joining multiple candidates with |, which is an invalid filename character and will require the end user to remove alternative candidates before renaming using other renaming rules.
Tested with ReNamer 7.9 and TrIDLib 1.0.2.
Renaming folders using file metadata
This script renames folders by reading a metadata tag from a representative file inside each folder, and appending the tag value to the folder name. It requires no third-party tools — only ReNamer's built-in CalculateMetaTag and WideScanDirForFiles functions.
A typical use case is music library organisation: given an album folder named "Artist - Title" containing MP3 files with an ID3 Year tag, the script produces "Artist - Title (1993)".
Setup
Add the folders you want to rename to ReNamer's file list (not the files inside them).
Script
Adjust MASK to match the type of files to search for inside each folder, and TAG to the metadata tag to extract. The full list of supported tag names is in the Meta Tags reference.
MASK = '*.mp3';
TAG = 'MP3_Year';
function FindFirstFile(const Folder: WideString): WideString;
Files: TWideStringArray;
Result := '';
SetLength(Files, 0);
WideScanDirForFiles(Folder, Files, False, False, False, MASK);
if Length(Files) > 0 then
Result := Files[0];
MasterFile, TagValue: WideString;
if not WideDirectoryExists(FilePath) then
Exit;
MasterFile := FindFirstFile(FilePath);
if MasterFile = '' then
Exit;
TagValue := WideTrim(CalculateMetaTag(MasterFile, TAG));
if TagValue <> '' then
FileName := FileName + ' (' + TagValue + ')';
WideScanDirForFiles scans the folder non-recursively for files matching MASK and returns their full paths. The first match is used as the source for the metadata tag. The WideDirectoryExists guard ensures the script acts only on folder entries and skips any regular files that may be in the list.
Tested with ReNamer 7.9.
Renaming files to match a reference file
This script renames files by taking the base name of a reference file located in the same directory, while preserving each file's own extension. It requires no third-party tools.
A typical use case is keeping companion files in sync. If a folder contains a reference file (.master for example) alongside generated or dependent files (data exports, logs, sidecar files), this script renames the companions to match the reference file's base name.
Setup
Add the files to be renamed to ReNamer's file list. The reference file must reside in the same folder as the files being renamed, but does not need to be in the renaming list itself.
Script
Adjust MASTER_FILE_MASK to match the reference file pattern.
MASTER_FILE_MASK = '*.master';
function FindFirstFile(const Folder, FileMask: WideString): WideString;
Result := '';
WideScanDirForFiles(Folder, Files, False, False, False, FileMask);
Result := Files[0];
MasterFile: WideString;
MasterFile := FindFirstFile(WideExtractFileDir(FilePath), MASTER_FILE_MASK);
if Length(MasterFile) > 0 then
FileName := WideExtractBaseName(MasterFile) + WideExtractFileExt(FilePath);
WideScanDirForFiles scans the source file's own folder for the first match against MASTER_FILE_MASK. WideExtractBaseName takes the base name from the reference file, and WideExtractFileExt(FilePath) preserves the original extension of the file being renamed. If no reference file is found, FileName is left unchanged.
