The topic pretty much covers it. What is Presets -> Create Links?
Hi airjrdn, don't be shy, just tell us what app you talked about.
I guess you mean ReNamer?
If i remember right this adds an link to windows folder-context menu to call ReNamer with this preset.
EDIT: no, it was to add links to "Send To"
Beta from 25 Juni 2008
* Added dialog for creating links to all presets, with load and rename options; , so you can easily place links to all presets in the "Send To" folder (for example)
http://www.den4b.com/forum/viewtopic.php?pid=2215#p2215
Sorry about that, I didn't even think to mention it.
Yes, ReNamer is the app I'm asking about.
That's awesome, thanks for the link!
