Does the ReNamer > CleanUp "prepare for SharePoint" check box remove all SharePoint prohibited special characters:
Look forward to your reply. Thanks.
Well, I just made the test and it removes all that symbols but the { } are replaced with ( )
That is correct. Illegal characters are removed and { } are replaced with ( )
