2 suggestions
First of I would like to thank you for your amazing software > ReNamer. Using this soft will save my actually lot of my time and do not need to rename files manually anymore.... THANK YOU A MILION!!!!!!!!!!!!!!!
While i was using it i came to few thinks which could be usefull for me and maybe for others too:
1. Possibility of adding comments to rules (I'm actually using 69 rules at the same time and sometimes i would like to add some note to rule... if someone ask why 69 rules, its because i rename hundreds of mp3's)
2. In remove rule add another option at how many first\last characters you can remove the string. Exampe: im trying to adjust file: a-testa-song_name.mp3 > using rule to remove a- > result: testsong_name.mp3, so my suggestion is too add a field where you can specify at which first\last character you can apply this rule, so if you add there number 3 it will try to remove the a- only at first 3 characters from the file which you are changing
... I want to add option to do not change content while changing rules, but i found it in settings!
Overall really good and sophisticated software, once again Thank you!
Hi syphoon, welcome.
Please remember next time
* to use an thread for ONE issue only.
* use more fitting subjects then "2 suggestions" only!
Thread one
ReNamer: i need comments for rules
You could use an existent thread for that request, i just searched for "comment rules"
See http://www.den4b.com/forum/viewtopic.php?id=554
thread two
ReNamer: improvement suggestion for Remove Rule
so if you add there number 3 it will try to remove the a- only at first 3 characters from the file which you are changing... I want to add option to do not change content while changing rules, but i found it in settings!
I am not sure if i really understood what you asked for.
You mean you want an result like:
testa-song_name.mp3
but you got:
testsong_name.mp3
Then just check "[X] First" in "Remove Rule" for your example.
If it is not that simple we can use RegEx Rule.
If you have more questions, just ask.
After a while i understand you better.
To search and replace an string with an another string or nothing
and only between pos n and the next m chars (for example: from pos 3 for the next 10 chars incl. char at start pos)
you can use an PascalScript Rule like this.
To search at two or more positions for other occurrences, add this script more then once.
//PascalScript Rule to extent the "Remove Rule"
//RegEx Search and Replace an String only between pos n and m
//To search and replace an string with an another string or nothing
//and only between pos n and the next m chars (for example: from pos 3 for the next 10 chars incl. char at start pos)
//you can use an PascalScript Rule like this.
//To search at two or more positions for other occurrences, add this script more then once.
//See the WIKI for more about using Rules => http://www.den4b.com/wiki/ReNamer:Rules
//in special => http://www.den4b.com/wiki/ReNamer:Rules:PascalScript
//and for more about the RegEx Syntax => http://www.den4b.com/wiki/ReNamer:Regular_Expressions
StartToSearchAtChar, ForTheNextNChars: integer;
substrB, substrM, substrA, RegExStrToRemove, RegExStrAsReplacement: WideString;
bRegExCaseSensitive, bRegExUseSubstitution: Boolean;
////// Settings
StartToSearchAtChar := 1; // use 1 to start at the beginning
ForTheNextNChars := 3; // use 999 to search all
RegExStrToRemove := 'a-'; //search for this between ' and '. Use '.+' for all
RegExStrAsReplacement := ''; // replace with this. Use '' to remove
bRegExCaseSensitive := TRUE;
bRegExUseSubstitution := FALSE;
///// Check the conditions
///// Do it
//Split the name into three parts (before/middle/after):
substrB := WideCopy(WideExtractBaseName(FileName),1,StartToSearchAtChar-1);
substrM := WideCopy(WideExtractBaseName(FileName),StartToSearchAtChar,ForTheNextNChars);
substrA := WideCopy(WideExtractBaseName(FileName),StartToSearchAtChar+ForTheNextNChars, 999);
//Remove the string:
substrM := ReplaceRegEx(substrM, RegExStrToRemove, RegExStrAsReplacement, bRegExCaseSensitive, bRegExUseSubstitution);
//Build the new name:
FileName := substrB + substrM + substrA + WideExtractFileExt(FileName);
end.HTH?
in special
I had some time to extent my script a little.
1. Optional search for the starting pos automatically by let the script searching for an char like '-'
2. Prompt the user with an info about the settings
Note: this script is not widely tested. So test it first with some test files.
substrB, substrM, substrM2, substrA, RegExStrToRemove, RegExStrAsReplacement, strpos: WideString;
bRegExCaseSensitive, bRegExUseSubstitution, binit: Boolean;
////// Settings
ForTheNextNChars := 9; // incl. the start pos. Use 999 to search all
// Find the StartToSearchAtChar automatically by searching the first occurrence of char 'x'
strpos := ''; // use '' to disable this feature
IF (strpos <> '') then
StartToSearchAtChar := pos(strpos, WideExtractBaseName(FileName));
///// Check the conditions (not really needed)
//IF (ForTheNextNChars = 0) Then exit;
//IF (ForTheNextNChars > Length(WideExtractBaseName(FileName))-StartToSearchAtChar) Then exit;
///// Do it
substrM2 := ReplaceRegEx(substrM, RegExStrToRemove, RegExStrAsReplacement, bRegExCaseSensitive, bRegExUseSubstitution);
///Information. Prompt the user one time with the current settings:
IF (binit=False) then
showmessage('Search only from char pos '+IntToStr(StartToSearchAtChar)
+ ' for the next ' +IntToStr(ForTheNextNChars) + ' chars incl. start position'
+ #13#10 + #13#10 + 'Settings:' + #13#10
+ 'StartToSearchAtChar found autom. by string: <' + strpos + '>' + #13#10
+ 'StartToSearchAtChar: <' + IntToStr(StartToSearchAtChar)+ '>' + #13#10
+ 'ForTheNextNChars: <' + IntToStr(ForTheNextNChars)+ '> incl. the start char' + #13#10
+ 'String to search in: <' + substrM + '>' + #13#10
+ 'RegExStrToRemove: <' + RegExStrToRemove + '>' + #13#10
+ 'RegExStrAsReplacement: <' + RegExStrAsReplacement + '>' + #13#10 + #13#10
+ 'Result for test string: ' + #13#10 + FileName + #13#10 + '<' + substrM2 + '>' + #13#10
// + 'bRegExCaseSensitive: <' + bRegExCaseSensitive + '>' + #13#10
// + 'bRegExUseSubstitution: <' + bRegExUseSubstitution + '>' + #13#10
binit :=True;
FileName := substrB + substrM2 + substrA + WideExtractFileExt(FileName);
end.HTH?
If yes, help two others too, and spent some money to Den4b Denis.
_
