#1 2010-10-11 10:08
[Suggestion] Remove whole old file name completely
Delete whole old file name completely
I want to suggest an additional text for the Remove rule below "Note:":
Tip: Check this and use an single '*' only to remove the whole old file name
(or like that big_smile)
EDIT: changed the subject line
#2 2010-12-16 13:59
Re: [Suggestion] Remove whole old file name completely
I don't think it is suitable for the Remove rule. Delete rule would be more appropriate.
The easiest and the most efficient way to delete the original filename is by using:
1) Delete: Delete from Position 1 until the End (skip extension)
#3 2015-05-06 19:02
Suggestion 1
Delete Rule: [_] Delete the current name
Would just set the options "Delete from Position 1 until the End (skip extension)" after clicking [Add Rule]
Suggestion 2
Insert Rule: [_] Replace the current name
#4 2015-06-03 14:21
How about adding this option to "Where" radio button group in Insert and Serialize rules ?
For example:
( ) Prefix
( ) Suffix
( ) Position ...
( ) After text ...
( ) Before text ...
(o) Replace original
[X] Skip extension
#5 2015-06-04 12:15
I would vote Yes for
Insert : Where: (o) Replace original
*I* see no real need for
Serialize : Where: (o) Replace original
*I* still see an use for
Delete: [X] Delete original name
Because there I would look for deleting the original name.
All other rules as 'Insert' and 'Serialize' could relay on first using "Delete: [X] Delete original" rule.
So since 'Insert' dialog have not much space, and for 'Serialize' I see no direct need, I want to vote still for "Delete: [X] Delete original".
It's not for my own use. I know how to do it on my own, but for new or random users I see the need for my suggestion.
"""I want to remove the current name. Where is that option? Perhaps in 'Remove' or 'Delete' or 'CleanUp'?..."""
#6 2015-06-04 12:46
Note: in 'UserInput' this is called "Replace current name", not "original name".
Just to note to be consistent, what ever you want to do.
#7 2015-06-19 12:49
ReNamer 6.2.0.3 Beta (2015-06-18):
* Added "Delete current name" option to Delete rule;
* Added "Replace current name" option to Insert rule;
