#1 2013-02-25 02:59
bocaseca
Upper case in brackets only
I'm sorry if my post is wrong,
please, i need help, my brain is going to explode reading the forum, is very good, full of information but i only know 2% of english
i want to uppercase the first letter of each word, but only the words which are inside of ( )
e.g.
               I'm stupid because i don't know english (very stupid)
               I'm stupid because i don't know english (Very Stupid)
#2 2013-02-25 10:09
Re: Upper case in brackets only
Hi bocaseca and welcome.
Don't worry, your english is not bad.
As addition you can use g00gle translater,
or add an sentence or two in your mother tongue to clarify.
To solve your issue we have to use an PascalScript rule.
See our wiki > http://www.den4b.com/wiki/ReNamer:Rules:PascalScript
I have to learn because i don't know ReNamer (It's not that heavy at all).txt
I have to learn because i don't know ReNamer (It's Not That Heavy At All).txt
USE:
1) PascalScript:
  Parts: TStringsArray;
  //Enter an regex to split your BASE file name into parts to an array:
  Parts := SubMatchesRegEx(WideExtractBaseName(FileName), '^(.+?)(\(.+\))$', FALSE);
  If (Length(Parts) <=0) then exit;
  //Now build you new file name (a array starts counting at zero), and add the Extension:
  // Capitalize Every Word	WideCaseCapitalize
  // lowercase			WideLowerCase
  // UPPERCASE			WideUpperCase
  // iNVERT cASE		WideCaseInvert
 FileName := Parts[0] + WideCaseCapitalize(Parts[1]) + WideExtractFileExt(FileName);
HTH?
#3 2013-02-25 15:47
bocaseca
Thanks a lot, you solved my problem at 100%, this is the most effective forum i ever seen,  thanks so much.
#4 2014-10-30 11:14
afh
It would be nice to have the Case rule as advanced renamer has it:
case rule in advanced renamer
#5 2014-10-30 21:55
afh
I'm really surprised for no opinion on this from administrator... I find it pretty useful. Using pascal script should be the last solution, I think...
No offense, but renamer should be over the free software...
fragments should be identified by the text between brackets according to regular expression rules (I hope I'm clear, I'm not a geek...)
#6 2014-10-30 22:29
Case manipulations on patterns are supported via \u \U \l \L flags in RegEx rule.
More details and examples here:
http://www.den4b.com/forum/viewtopic.php?id=1857
Also explained here:
http://www.den4b.com/wiki/ReNamer:Regul … ipulations
In future, please don't resurrect old threads, start a new one.
#7 2014-10-31 08:37
afh
Thanks!
I'm new on this forum and I searched for Case rule, but I didn't expect to have this implemented in regexp smile
