#1 2021-06-22 14:28
Lauraq
execute script only with certain extension
Hi smile
Is possible execute script only with certain extension?
I would like a script that acts only on .flac files and leave all the .jpg ones alone
Thanks smile
#2 2021-06-24 13:59
Re: execute script only with certain extension
Do that inside of the script (and next simply run the script on all files)
https://www.den4b.com/wiki/ReNamer:Pasc … _Utilities
WideExtractFileExt( FileName )
Example:
 sExte: WideString;
  sExte := WideExtractFileExt(FilePath);
//This block is not need at all for this very challenge:
  if( WideUpperCase(sExte) = '.JPG') then
     //ShowMessage( ' do nothing for ' + FileName )
//Process only if extension match:
  if( WideUpperCase(sExte) = '.FLAC') then
     //ShowMessage( FileName )
     FileName := 'That is a FLAC_' + FileName;
#3 2021-06-24 18:43
Lauraq
thanks but don't work. It permit the rename of the jpg in the list and put "That is a FLAC" on top of my flc renamed file. For example:
01 - Azzurri gli oceani
after
That is a FLAC 01 - Azzurri gli oceani
sad
#4 2021-06-25 08:05
after
sad
Exactly as requested:
#5 2021-06-25 08:40
Lauraq
sorry, i think google translate made some mistakes.
I'll try to be clearer.
If I use a script like this
http://www.den4b.com/forum/viewtopic.php?id=2239
the changes it will make will be on both flac and jpg files present in the folder.
I would like a script to tell all the commands that I will then add, which must act only on the flac and mp3 files and which must not touch the jpg
#6 2021-06-25 09:11
Load only certain file types:
http://www.den4b.com/wiki/ReNamer:Filter_settings
>> Masks  >> All added files (or folders as files) must match specified masks. For example, if you enter *.jpg;*.gif;*.png as an Include mask,
Or select only certain file types in the pane:
http://www.den4b.com/wiki/ReNamer:Files_menu
Files pane has a context menu for managing files, which can be accessed by right-clicking on the files pane
>> Select by Extension
Rules will then work only on that selected file types, ignoring other files in folder.
#7 2021-06-25 12:58
Lauraq
thanks, the Mask works fine but every time I close and reopen the program, I have to reset it because it doesn't memorize the settings I gave.
However my dream was different, I wanted to create a single preset with some commands that act on the flac and other commands that act on the jpg. It would be nice if, among the Rule entries, there was one that allows you to decide which types of files to apply those rules to
#8 2021-06-25 13:05
Than that?
http://www.den4b.com/wiki/ReNamer:Using_presets
A "preset" is a set of rules that is saved with a user-defined name.
It can optionally save the Filter setting also.
>> Masks  >> All added files (or folders as files) must match specified masks. For example, if you enter *.jpg;*.gif;*.png as an Include mask,...
#9 2021-06-25 13:13
Lauraq
I don't understand, do you understand what I want? smile
I would like ONLY ONE preset that contains rules to apply to flac, mp3 and different rules to apply to JPGs
#10 2021-06-25 13:54
Either make two presets (post #8), one for each extension or a set of extension,
or use script (post #2) with different commands based automatically on current extension.
One single preset with different rules automatically for different extension is not supported right now, as far as I see.
I could imagine a kind of "master preset" which contains two or more "normal" presets and execute them one after the other, but I am thinking that is not possible right now.
