Regular Expressions reference
Introduction
Regular Expressions (RegEx) is a syntax for specifying patterns of text to search and replace, which can be used for renaming files via the Regular Expressions renaming rule.
Special metacharacters allow you to specify, for instance, that a particular string you are looking for occurs at the beginning or end of a line, or contains N recurrences of a certain character. Metacharacters, such as $ . ^ { [ ( | ) * + ? \ are interpreted according to their individual meaning, instead of finding a literal match for them.
In this document, the subject text which is checked against a pattern for a possible match is shown in bold. Parts of the subject text may be color-coded to provide a clue as to why a certain part matches (green color), or does not match (red color).
Simple matches
When the search string does not contain any metacharacters, the RegEx processor works like "normal" search. It tries to find an exact copy of the search string. This is also known as a literal match.
If you want to find a literal match for a metacharacter, put a backslash \ before it. The \ character is called an escape character, because it lets the metacharacter escape from its special duty, and lets it act as a normal character. Its combination with a metacharacter is called escape sequence.
For example, metacharacter ^ matches the beginning of string, but pattern \^ matches ^ character literally. Similarly, pattern \\ matches \ character literally.
Pattern Matches Remarks
foobar foobar This pattern does not contain any metacharacters, so all characters are matched literally.
\^FooBar ^FooBar The \^ escape sequence matches the ^ character literally.
Escape sequences
We already saw one use of escape sequence (above).
Specific escape sequences are interpreted as special conditions, as listed below.
Pattern Remarks
\xnn Character represented by the hex code nn
\x{nnnn} Two bytes char with hex code nnnn (unicode)
\t Tab (HT/TAB), same as \x09 (Hex 09)
\n New line (NL), same as \x0a (Hex 0a)
\r Carriage return (CR), same as \x0d (Hex 0d)
\f Form feed (FF), same as \x0c (Hex 0c)
foo\x20bar Matches foo bar (note the space in the middle), but does not match foobar
\tfoobar Matches foobar preceded by a tab (the tab is needed for the match)
Note that the tab, new line, carriage return, and form feed are all known as white space characters, because they are normally not visible on display, but the RegEx processor can distinguish between them.
Character classes
A character class is a list of characters surrounded by square brackets [ and ], which will match any one (and only one) character in that class.
Note that:
  • The characters are not separated with a comma or a space.
  • If you repeat any character in the list, it is considered only once (duplicates are ignored).
  • A hyphen character - is used to indicate a range of characters.
Pattern Remarks
[abcdef] Matches any one of a, b, c, d, e, or f.
[c-m] Matches any one small alphabetical character from c through m.
[G-J] Matches any one capital alphabetical character from G through J.
[a-zA-Z] Matches any one alphabetical character (small or capital).
[5-8] Matches any one numerical character from 5 through 8.
[\x00-\x1F] Matches any one character with a hexadecimal value in range from 0 through 1F.
This range includes all ASCII control characters, most of which are non-printable.
There are some special conditions:
  • If you do not want any of the characters in the specified class, then place ^ at the very beginning of the list, which means "none of the characters listed in this class".
  • If you want [ or ] itself to be a member of a class, put it at the start or end of the list, or use an escape sequence by putting \ before it.
Pattern Remarks
[-az] Matches a, z, and -.
Note the - is at the beginning of the pattern, the escape sequence is not needed.
[a\\-z] Matches a, z, and -
Note the - is not at the beginning/end of the pattern, the escape sequence is needed.
[^0-9] Matches any non-digit character.
[]-a] Matches any character from ] to a.
Note the ] is at the beginning of the pattern, the escape sequence is not needed.
foob[aeiou]r Matches with foobar and foober, but not foobbr, foobcr, etc.
foob[^aeiou]r Matches with foobbr, foobcr etc. but not foobar, foober, etc.
Predefined classes
Some of the character classes are used so often that RegEx has predefined escape sequences to represent them.
Pattern Description
\w Alphanumeric character, including an underscore _ character.
\W Non-alphanumeric character.
\d Numeric character.
\D Non-numeric character.
\s White space character, same as [ \t\n\r\f] character class.
\S Any character, excluding white space characters.
. Any character.
Notice that the capitalized classes act as negatives, for example, \W has an inverse meaning of \w.
Word and text boundaries
A word boundary \b matches a position between a word character \w and a non-word character \W. For the purpose of a word boundary position, the start and end of text are treated like a non-word character \W. These markers are commonly used for matching patterns as whole words, while ignoring occurrences within words.
Pattern Description
\b Word boundary.
\B Not word boundary.
\A or ^ Start of text
\Z or $ End of text
For example, \bhis\b will match a whole word his, but will not match this, history or whistle.
Iterators
Iterators (quantifiers) are meta-characters that specify how many times the preceding expression has to repeat. For example, finding a numeric sequence exactly 3 to 5 digits long.
Iterators can be greedy or non-greedy. Greedy means the expression grabs as much matching text as possible. In contrast, the non-greedy expression tries to match as little as possible.
All iterators are greedy by default. Adding ? (question mark) at the end of an iterator makes it non-greedy.
For example:
  • when b+ (a greedy expression) is applied to string abbbc, it matches bbb (as many as possible),
  • but when b+? (a non-greedy expression) is applied to abbbc, it matches b (as few as possible).
Iterator Description Greedy? Alternative
* zero or more Yes {0,}
+ one or more Yes {1,}
? zero or one Yes {0,1}
{n} exactly n times Yes
{n,} at least n times Yes
{n,m} at least n but not more than m times Yes
*? zero or more No {0,}?
+? one or more No {1,}?
?? zero or one No {0,1}?
{n}? exactly n times No
{n,}? at least n times No
{n,m}? at least n but not more than m times No
Let's see some examples:
Pattern Remarks
foob.*r matches foobar, foobxyz123r and foobr
foob.+r matches foobar, foobxyz123r but not foobr
foob.?r matches foobar, foobbr and foobr but not foobxyz123r
fooba{2}r matches foobaar
fooba{2,}r matches foobaar, foobaaar, foobaaaar but not foobar
fooba{2,3}r matches foobaar, foobaaar but not foobaaaar or foobar
Alternatives
A RegEx expression can have multiple alternative characters or subexpressions. The metacharacter | (vertical pipe) is used to separate the alternatives. For example, fee|fie|foe will match fee, fie, and foe in the subject text.
It is a common practice to group alternatives into parentheses, to make it easier to identify and distinguish them. For example, fee|fie|foe can be written as (fee|fie|foe) or as f(e|i|o)e.
Alternatives are tested for a match in the order in which they appear, from left to right, iterating until the full expression match is found or all alternatives have failed to match. For example, when matching foo|foot against barefoot, the first alternative foo will match first.
Pattern Remarks
fee|fie|foe Matches fee, fie, and foe.
f(e|i|o)e Matches fee, fie, and foe.
foo(bar|foo) Matches foobar or foofoo.
Also remember that alternatives cannot be used inside a character class (square brackets), because | is interpreted literally within []. That means that [fee|fie|foe] is same as [feio|], where repeating characters are treated as duplicates, and ignored.
Subexpressions
Parts of a pattern can be enclosed in round brackets (), just like using brackets in a mathematics formula a+(b+c). Each part that is enclosed in brackets is called a subexpression. Subexpressions can provide clarity in complex expressions, and can be referenced in both the expression itself and in the replacement pattern.
Pattern Remarks
(fee|fie|foe)bar Subexpression fee|fie|foe is clearly separated from the remaining expression.
(foobar){2,3} Matches foobar if repeated 2 or 3 times, i.e. foobarfoobar and foobarfoobarfoobar.
foobar{2,3} Matches fooba followed by the character r repeated 2 or 3 times, i.e. foobarr and foobarrr.
foob([0-9]|a+)r Matches foob0r, foob1r, foobar, foobaar, foobaaaar, etc.
Backreferences
Backreferences allow you to reference individual subexpressions, enabling complex repeating patterns.
Each subexpression is identified by its index (order of appearance) in the full expression and can be referenced using a backslash \ followed by the subexpression index, e.g. \1, \2, \3, and so on.
Pattern Remarks
(.)\1+ Matches any character that is repeated at least twice, e.g. aaaa and cc.
(.+)\1+ Matches any sequence of characters that is repeated at least twice, e.g. aaaa, cc, abababab, 123123.
(cat|dog) \1 Matches cat cat or dog dog.
Named groups
Named groups work like numbered subexpressions but assign a descriptive name to each group, making complex patterns easier to read and maintain. A named group is referenced by name rather than by its position in the expression.
To define a named group, use (?P<name>pattern). To back-reference a named group within the same expression, use (?P=name). To reference a named group in the replacement pattern, use ${name}.
Pattern Remarks
(?P<year>\d{4})-(?P<month>\d{2})-(?P<day>\d{2}) Defines three named groups: year, month, and day. Each group captures the corresponding part of a date string.
(?P<word>\w+) (?P=word) Matches a repeated word, e.g. the the. The back-reference (?P=word) requires the same text that was captured by the word group.
Named groups can also be referenced by name in the replacement pattern, instead of by number:
Find Replace Description
(?P<year>\d{4})-(?P<month>\d{2})-(?P<day>\d{2}) ${day}-${month}-${year} Reformat a date from yyyy-mm-dd to dd-mm-yyyy.
For example, "2024-10-25" becomes "25-10-2024".
Named groups are particularly useful in long expressions with many groups, where keeping track of group numbers becomes error-prone.
Substitutions
Subexpressions can also be referenced in the replacement pattern, allowing you to assemble the output using individual subexpression matches.
Each subexpression is identified by its index (order of appearance) in the full expression and can be referenced using a dollar sign $ followed by the subexpression index, e.g. $1, $2, $3, and so on. The full expression match can be referenced using $0.
Let's see some examples of replacement with substitutions:
(\w+) (\w+) $2, $1 Switch two words around and put a comma between them.
For example, "John Smith" becomes "Smith, John".
\b(\d{2})-(\d{2})-(\d{4})\b $3-$2-$1 Find dates in dd-mm-yyyy format and reverse them into yyyy-mm-dd format.
For example, "25-10-2007" becomes "2007-10-25".
Note that the last example is not a robust approach for handling dates, because \d matches any digit in 0-9 range. This means that sequences like "00-00-0000" and "99-99-9999" will also match this pattern, but do not represent a valid date.
Lookaround assertions
Lookaround assertions (lookahead and lookbehind) let you enforce conditions on text immediately before or after the main match, without including that surrounding text in the matching result.
Assertions are zero-width as they consume no characters, and come in four forms: positive/negative lookahead (checks ahead) and positive/negative lookbehind (checks behind).
Type Syntax Description
Positive lookahead foo(?=bar) Matches foo only if immediately followed by bar ("bar" is not consumed).
Negative lookahead foo(?!bar) Matches foo only if not immediately followed by bar.
Positive lookbehind (?<=bar)foo Matches foo only if immediately preceded by bar ("bar" is not consumed).
Negative lookbehind (?<!bar)foo Matches foo only if not immediately preceded by bar.
Pattern Subject Remarks
\d+(?= euros) 100 euros Matches 100 (digits only if followed by space and "euros").
\d+(?! euros) 100 dollars Matches 100 (digits only if not followed by space and "euros").
(?<=EUR )\d+ EUR 50 Matches 50 (digits only if preceded by "EUR" and space).
(?<!EUR )\d+ USD 30 Matches 30 (digits only if not preceded by "EUR" and space).
Non-capturing groups
Non-capturing groups allow you to apply quantifiers, alternatives, or other operations to a subpattern without creating a numbered capture. This avoids unnecessary captures, keeps backreference numbering unaffected, and is especially useful when you need grouping only for structure or performance, without intending to reference the group later.
The syntax is (?:subpattern) to group the subpattern without creating a capture.
Let's see some examples, with and without non-capturing groups:
(Mr|Mrs) (\w+) Mr Smith Matches the full salutation and name.
Captures title (1st backreference: Mr) and name (2nd: Smith).
(?:Mr|Mrs) (\w+) Mr Smith Matches the full salutation and name.
Captures only name (1st backreference: Smith). Title is grouped but not captured.
(https?)://([^/\s]+) https://example.com Matches the full URL.
Captures protocol (1st backreference: https) and domain (2nd: example.com).
(?:https?)://([^/\s]+) https://example.com Matches the full URL.
Captures only domain (1st backreference: example.com). Protocol is grouped but not captured.
Text case adjustments
Subexpressions can also be used to adjust the text case (upper case, lower case) of certain patterns, which otherwise cannot be easily achieved with generic text case manipulation rules.
The following flags can be combined with subexpression references in the replace pattern:
Flag Description
\L Convert all characters to lowercase.
\l Convert only the first character to lowercase.
\U Convert all characters to uppercase.
\u Convert only the first character to uppercase.
For example, we can do the following manipulations:
Input Find Replace Result
hello WORLD (.+) (.+) $1 $2 hello WORLD
hello WORLD (.+) (.+) \U$1 $2 HELLO WORLD
hello WORLD (.+) (.+) $1 \L$2 hello world
hello WORLD (.+) (.+) \u$1 \L$2 Hello world
Inline modifiers
Inline modifiers let you change matching behaviour for part of a pattern, without affecting the rest. The most practical use for file renaming is enabling case-insensitive matching selectively — for example, when only part of a pattern needs to match regardless of capitalisation.
The syntax is (?modifier) to enable and (?-modifier) to disable. A modifier can also be scoped to a specific subpattern using (?modifier:pattern), so that it applies only within that group and leaves the rest of the expression unchanged.
The most commonly useful modifiers are:
Modifier Description
i Case-insensitive matching.
m Multi-line mode: ^ and $ match the start and end of each line, not just the whole string.
s Single-line mode: . matches any character including line-break characters.
An inline modifier affects everything that follows it in the current group or expression:
(?i)report Report_2024.pdf Matches report in any capitalisation.
(?i:copy) of (.+) Copy of Report.pdf The (?i:...) form scopes case-insensitive matching to copy only; the rest of the pattern remains case-sensitive.
See also
